mhobbsy 0 Report post Posted June 27, 2012 Hi everyone, I have the terrible marbles in a twin can noise coming from the vanos unit and was wondering if any has had any success here in repairing them as I'm seriously considering Dr vanos but its rather pricey and your relying on parts arriving and yours making it back to them to get the core refund. Any help is appreciated. Cheers Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted June 27, 2012 Hi everyone, I have the terrible marbles in a twin can noise coming from the vanos unit and was wondering if any has had any success here in repairing them as I'm seriously considering Dr vanos but its rather pricey and your relying on parts arriving and yours making it back to them to get the core refund. Any help is appreciated. Cheers I did mine a few years back, very easy. It's not dual vanos, only intake side has it on the S50.I had the instructions from TIS as I work at a BMW dealer but I would assume you would find them on the interweb. Quote Share this post Link to post Share on other sites
nastnas 9 Report post Posted June 28, 2012 beisan systems have just released a kit, I have it in my car, it is excellent! If you are in Auckland, you're welcome to have a listen... Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted June 28, 2012 mikes is s52 duel vanos.. on line tis is prity poor greg how is the genuine version, any chance you could fax a procedure copy to us so we can help him out? Quote Share this post Link to post Share on other sites
Alexmsk77 0 Report post Posted June 23, 2013 recommend that you read the information about the repair kits for BMW vanos online www.vanos-bmw.com Quote Share this post Link to post Share on other sites
///MPROVD 135 Report post Posted June 27, 2013 im replacing the seals in my single vanos s50 this weekend im using this wright up http://www.beisansystems.com/procedures/eu...s_procedure.htm Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted June 27, 2013 Ordered all parts for my dual vanos rebuild last week from basian and BMW so will be giving that a go in the following weeks. Also doing before and after dyno runs too to see what a difference it makes. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted June 27, 2013 Ordered all parts for my dual vanos rebuild last week from basian and BMW so will be giving that a go in the following weeks. Also doing before and after dyno runs too to see what a difference it makes. It's funny - I've seen people do dyno runs, and see no difference (on other forums etc). Ours REALLY felt difference. I can't see how you wouldn't notice it on the chart. Will be good to see results! Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted June 27, 2013 I've just ordered the Basian systems rattle kit and vanos repair for my S50B30. It looks tricky im a bit nervous ripping all that lot to bits. Any tips or trick guys? Do you need the cam allingnment bridge? Where do you get/beg/borrow/steal one of those? Is it tricky to get it all back on alligned properly with the cams? Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted June 28, 2013 The basian write up is an extremely detailed, step by step guide to do it, that's what I'm using as a guide so should make things pretty clear and shouldn't need the special tools either by the looks of things. Quote Share this post Link to post Share on other sites
///MPROVD 135 Report post Posted June 28, 2013 shouldn't be too hard to do just got to keep an eye on the oil pump orientation. might just have to mark it before removal Quote Share this post Link to post Share on other sites
Alexmsk77 0 Report post Posted June 30, 2013 Hi everyone, I have the terrible marbles in a twin can noise coming from the vanos unit and was wondering if any has had any success here in repairing them as I'm seriously considering Dr vanos but its rather pricey and your relying on parts arriving and yours making it back to them to get the core refund. Any help is appreciated. Cheers recommend that you read the information about the repair kits for BMW vanos online www.vanos-bmw.com Quote Share this post Link to post Share on other sites
///MPROVD 135 Report post Posted June 30, 2013 just replaced all the seals in my single vanos s50 successfully it wasn't too hard but it was time consuming havnt noticed much difference i had a small issue before with when the car was cold there is an small jolt when you start to accelerate but that has seem to of gone now. also pretty much every old seal was well destroyed Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted July 28, 2013 I finally did the S50B30 single vanos with Besian systems rattle and vanos kits, took me a while but all good. Turns out i have an early 9/93 model that doesn't look like the instructions. No timing marks or TDC lock pin on front ballancer, only at the back by starter motor lock pin into fly wheel (buried deep) so glad i marked all on the way out so just put it back together same so sweet. Also cant get sprocket hub off cam without taking cam out so the S62 sprocket hub diaphragm spring and pressure plate (11-36-7-833-218) i bought didnt go on. Quote Share this post Link to post Share on other sites
