slasH 4 Report post Posted July 25, 2012 Hi guys, few weeks ago my dsc light came on intermittently and that eventually lead to the abs light coming on and then leading to limp mode (trans fail safe) As I suspected I got this confirmed with bm workshop to be a faulty abs/dsc unit, due to the hefty replacement costs im looking to get this repaired if possible (as i saw this is possible through some research) I searched on these forums for similar problems but the last one i saw was way back in 2008 lol. Is there anyone still around that repair these units? If so can you please let me know of their contact details Thanks in advance Quote Share this post Link to post Share on other sites
HELLBM 1672 Report post Posted July 25, 2012 Can help with a replacement. regards Ray Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted July 25, 2012 Anything Electronic in Nelson BMW ABS Repairs Quote Share this post Link to post Share on other sites
Jo Blogs 11 Report post Posted August 1, 2012 Can help with a replacement. regards Ray ABS engineering in Tauranga. $200 for the last DSC unit i sent them. Rebuilt. Not worth buying 2nd hand as the fault occurs all to often and you will be doing the same repair in 6-18 months. Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted August 8, 2012 thanks got the unit back repaired. there is some instructions disconnect battery before install and check pump earth before reconnection how do i check the pump earth? its a fully enclosed unit :S? Quote Share this post Link to post Share on other sites
Jo Blogs 11 Report post Posted August 8, 2012 (edited) thanks got the unit back repaired. there is some instructions disconnect battery before install and check pump earth before reconnection how do i check the pump earth? its a fully enclosed unit :S? Use a Multi-Meter and check at the plug (Ohm's test). There is two wires that are noticeably larger than the others. One is a positive feed..the other is the earth. *May pay to probe the plug with a sewing pin...not the Multimeter probe as it may damage the female terminal int hte plug* Edited August 8, 2012 by Winckel Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted August 8, 2012 is this of the unit or the external plug socket ? Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted August 8, 2012 ok im guessing its the external plug since u said the "multometer prob may damage" thanks! Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted August 8, 2012 awesome all fitted and abs/dsc lights gone, will test drive it soon and hope for the best . Thanks for all the help! but ever since i picked it up after i gave it to the workshop for testing i noticed that the top row of leds on my stereo had disappeared (thought it was due to abs unit) but now that hasn't come back. il have to look into it, any ideas? Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted November 15, 2015 Hey guys.. thought i should use this same thread. The fault appeared again! 3 years later.. last time cost me $220, sent it off to anything electronic again this time iv been told in 2012 the repair carried out was for a minor problem, it has now developed a more major problem in two different areas requiring extensive repair costing $365. just wondering if there updated Bosch units where this issue has been fixed for good? or is it going to be a $300 or so repair every 2/3 years? Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted November 15, 2015 Whent he exchange rate was better, I got a brand new unit for NZ$480? or $580? from mafshop.de Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted November 15, 2015 (edited) is the brand new unit also going to have similar problems, or have these issues been fixed for good? I might consider this option if that is the case. Whent he exchange rate was better, I got a brand new unit for NZ$480? or $580? from mafshop.de ouch, $700nzd for a new unit.. https://www.maf-shop.com/en/abs-control-unit Edited November 15, 2015 by slasH Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted November 16, 2015 is the brand new unit also going to have similar problems, or have these issues been fixed for good? I might consider this option if that is the case. ouch, $700nzd for a new unit.. https://www.maf-shop.com/en/abs-control-unit Well, our first one lasted 14 years, so the replacement should be roughly as good None of the repairers I spoke with inspired any confidence. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 16, 2015 I have no problem with the repairers I use because we communicate and know what can & can't be repaired. Some units can be repaired, some can't. Some have been played with by morons and can't be re done. The repairer also needs correct info on the fault codes so he can confirm the fault is actually in the control unit and not else where.. collectively we work together Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 16, 2015 is the brand new unit also going to have similar problems, or have these issues been fixed for good? I might consider this option if that is the case. ouch, $700nzd for a new unit.. https://www.maf-shop.com/en/abs-control-unit Well considering the exchange rate at the minute - that's not bad pricing. Was much cheaper when i got mine a few years back. There are different circuits that fail in them, some not repairable (as mine was not) Surely the $380 you have been quoted to fix this one puts $700 into perspective. I have no problem with the repairers I use because we communicate and know what can & can't be repaired. Some units can be repaired, some can't. Some have been played with by morons and can't be re done. The repairer also needs correct info on the fault codes so he can confirm the fault is actually in the control unit and not else where.. collectively we work together Word! The units have a habit of lying with their fault codes. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted November 17, 2015 (edited) Am also havnt the same delemma at the moment on what to do with mine. Edited November 17, 2015 by euroriffic Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted November 19, 2015 (edited) Had some help from the technician there, was helpful in my decision to have it repaird, might be helpful for you too. Just wanted to ask a few questions regarding this unit before proceeding with the repair to try understand the problem 1. I am a bit confused with this module. I could be wrong but when I researched it online the first time and understood that these units are faulty by factory standards and it only emits this problem once, and once its been repaired the problem should not happen again? The failure of the internal aluminum connection links that can develop with these units is well documented as you have seen. When your ABS controller was here in 2012 the only fault diagnosed was with the main Earth connection. As the other aluminum links showed no sign of degrading is was decided not to replace them hence the lower cost at the time. In the ensuing three years some of the other links have started to fail. 2. Is it the issue of cracked soldering bosch wires in the modules leading to broken connections emitting error codes or something more than that? Due to the fact that we can see failed aluminum links in your unit I am assuming that this is the cause of the faults you are having with your ABS. These units are also prone to software issues as well that requires re-flashing of the programming, but we are not able to deal with those. 3. whats caused this to happen again. The failed link fault is caused by vibration/heat stress over a prolonged period. 4. How can I prevent this? .There is nothing that can prevent this fault other than replacing the links. 5. Is it likely to happen again after this times repairThis particular fault is unlikely to happen again once all the links are replaced, but this does not mean you will not have other faults that may develop with this module 6. Am I better off buying a another unit for cheaper and recode it? .Are you better off buying another unit? If you buy a second hand unit you may well be buying into the same issue, as for a new one the cost is between $1200 to $2000 unless you are able to purchase ex overseas but then there is risk with that as well.7. Have Bosch updated these units with this issue fixed for good? To my understanding Bosch have not updated these units as they are now obsolete and no longer used for later model BMW's. Edited November 19, 2015 by slasH Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted December 13, 2015 My unit couldnt be repaird this time after sending it back twice.. anyone got one for sale? Quote Share this post Link to post Share on other sites
