antil33t 90 Report post Posted August 10, 2012 Is there any way, other than ripping into the dash to work out which heater core an E34 uses? I'm wanting to replace all the O-Rings hoping that will fix my errant coolant smell that I can smell when the heater is in use. Appears to be a few kinds?! http://realoem.com/bmw/partgrp.do?model=HJ...hg=64&fg=15 Pelican Suggests it might have this one? First one looks easier to replace rings, 3 instead of 5 or so Might just have to rip into it... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 10, 2012 You might find it's the matrix that is leaking and not the "O" rings. You would need to replace the "O" rings anyway. These should be available X the dealer or you can get them from Seal House Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted August 10, 2012 yucky job i think you can see once you remove the glovebox. better site for cross referencing parts etc http://bmwfans.info/parts/catalog/E34/Tour...r_conditioning/ i have most of the heater core types if you need one. maybe even new ones?? Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted August 10, 2012 After dismantling my E34s interior, I must say the heater matrix is probably one of the hardest things to remove... Easier to pull an engine or gearbox out! Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted August 11, 2012 I've done an E30 Heater Matrix, wasn't fun, but for the E30 it was only the 'rings, Was going to purchase the rings, rip into it and inspect it, if all well I can just throw the new 'rings in and be on my way. Since It's my only working car right now... Quote Share this post Link to post Share on other sites
