Ace Of Spades
M20 PFL vs M20 FL 2.5ltr
I have a FL e30 325i with the piston rings starting to go and I have got a spare m20 b25 but its PFL...
Is there any differences between the PFL and the FL m20s? Or do they just swap right over?
If so what are they?
Any info would be awesome as im on break for 2 weeks and would love to get this done asap!
Sam
same engine, wait for an experts answer though :)
Edited by _Matt_
You'll probably have to swap the entire loom and ecu aswell. I'm pretty sure the crank angle sensor is located differently, but there may also be another way around this.
Have you thought of mixing & matching? I hear you can get more power using the PFL head on a FL short block, but don't quote me on this.
Have a search on e30tech.com/forums or r3vlimited.com, they both have a wealth of information.
just use the bare engine block and manifolds. use all your original electrics that are in the car etc.
i think the early engine may have higher compression pistons??
what happened to the m50b25 conversion??
Still haven't sold the engines yet so the bank balance is quite empty :(
Ok, the other engine is striped appart from the manifold, head and block.
So basically the fl loom will attach to all the pfl plugs on the engine??
André3000: I have thought about it but i'm really looking for the easy way to do it as i'm trying to sell the car but if it doesn't sell there will be an m50 going in :D
P.S
(But if anyone is interested in a m20 b25 engine I have two which I can sell (1 mint other needs new piston rings)
PM if interested would like around a 1g for both.)
I used a PFL block on my FL 325i with all the original FL components. Don't remember having any issues.
I think PRL block was 9.5 CR compared to 8.8 CR on FL iirc
P.S
use all the face lift sensors , electrics , front damper hub etc etc , only use the old block , and manifolds should be ok
Pfl or pre 88 are 9.7:1 block code 25 6E 1
Fl SA build 9.4:1 block code 25 6E 2
Fl US spec 8.8:1 block code 25 6K 1 or 2
