kevinator9 57 Report post Posted November 5, 2012 Hi Guys, Got myself a towbar for light trailers to help in moving etc. Hardware is simple enough to install just wondering if anyone has a PFL E30 with a towbar that is all wired up and if they could show me where the wiring is run and where it is connected to etc. I have searched for wiring diagrams but I can't find anything helpful. Thanks for any help in advance, Andrew Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted November 5, 2012 When I did my e36 I just followed the guide on the box the plug came in and connected them into the corisponding wire out of the lamp holders and ran the cable up through the boot, think there was even a grommet to bring it through too Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted November 5, 2012 (edited) I used these Bosch clips for wiring with a Narva trailer connector (flat, 12 pin type? it had two rows of sockets). Match, connect and press. No soldering etc http://www.siliconhose.com.hk/ebay2011/Top...0Gland/KW03.JPG wiring diagram, look through it and get wire colour correct Just google a couple of extra sources and double check. http://www.wedophones.com/Manuals/BMW/1989...ng%20Manual.pdf http://www.wedophones.com/Manuals/BMW/1985...ng%20Manual.pdf Google : e30 rear light wiring diagram edit: I connected it before the rear tail light plug, and right above the rear light cover Edited November 5, 2012 by dubman Quote Share this post Link to post Share on other sites
kevinator9 57 Report post Posted November 5, 2012 Yea I thought right above the tail lightbulb holder would be a good spot to wire it in. Confident enough to work out the connections etc to get it working. The main thing I was looking for was the way the towbar wire is routed. As euroriffic says his E36 had a grommet already. I have had a look on mine but can't seem to find anywhere to get it from the outside to the inside of the boot. Thanks Again. Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted November 5, 2012 Yea I thought right above the tail lightbulb holder would be a good spot to wire it in. Confident enough to work out the connections etc to get it working. The main thing I was looking for was the way the towbar wire is routed. As euroriffic says his E36 had a grommet already. I have had a look on mine but can't seem to find anywhere to get it from the outside to the inside of the boot. Thanks Again. I just slammed my bootlid shut on top of it, seemed to be alright lol. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted November 5, 2012 (edited) On mine there was a hole already for it, I'll double check where for you, and can get a picture if you want? I wired the towbar into the wires above the Left Tail-light too, but made a separate earth for the earth wire, just using a crimp 0 connection under one of the bolts securing the lock. Edit: There was a hole directly beside the Left rear bumper/towbar mount, comes through directly under the left rear tail-light, and then beside where the towbar sticks out my bumper also had 2 screw-holes on the underside for attaching the trailer plug to the bumper. Edit 2: If there isn't one then just go nuts with a 10mm drill bit Just make sure you pick a safe spot to drill. Edited November 5, 2012 by huff3r Quote Share this post Link to post Share on other sites
kevinator9 57 Report post Posted November 5, 2012 If you could get a photo Paul that would be great! Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted November 5, 2012 You can just see to the right of the bracket where the wire is going through. This pic shows the holes I found to mount the plug on. 2 self-tapping screws and it was done Shows where it comes through on the inside. And the wiring. You can see the separate earth I made, as prior to that it didn't work. Quote Share this post Link to post Share on other sites
kevinator9 57 Report post Posted November 5, 2012 Awesome! Just what I was looking for, cheers mate. Quote Share this post Link to post Share on other sites
