Garett 103 Report post Posted November 23, 2012 Just out of interest, would anyone be interested in a engine fan delete kits? includes a bracket and fan with wiring, relay, thermo switch, that you can just slide in the place of how your fan shroud is fitted with instructions, to get rid of your fan running off the viscous hub. and also x braces for the e36? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted November 23, 2012 Interested in the fan part.. not so much wiring. I used an 80/88c thermo switch, have it wired so that the low speed relay doesn't switch the aux fan on to low speed from temperature, instead turns on the fan I installed, which runs faster than the low speed. both should theoretically turn on if it gets to 88c. Some cars, like the E34 I was able to wire in the fan without adding any other major amount of exposed wires, as everything you need is inside the axillary fan relay box. except to the new fan. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted November 23, 2012 I'd be interested, depending on final costs etc as my viscous just decided to s**t itself Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted November 23, 2012 I'd be interested, depending on final costs etc as my viscous just decided to s**t itself +1, my one in the E30 is still fine and never overheats, but isn't as new anymore. plus I need to free up them horsepowers Quote Share this post Link to post Share on other sites
Apex Effects 3 Report post Posted January 11, 2013 +1 Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted January 11, 2013 Got a price in mind? Quote Share this post Link to post Share on other sites
