vendt 1 Report post Posted November 29, 2012 (edited) Hi all emission air pump has died my mechanic reckons not really needed in NZ does anyone run there car with out this or do i need to replace it? my car's a e46 330i m-sport 2000 if that helps.thanks Edited November 30, 2012 by vendt Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted November 30, 2012 Not needed, throw it away. Quote Share this post Link to post Share on other sites
tobytoblerone 3 Report post Posted November 30, 2012 Hi all emission air pump has died my mechanic reckons not really needed in NZ does anyone run there car with out this or do i need to replace it? my car's a e46 330i m-sport 2000 if that helps.thanks What a lazy mechanic. Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted November 30, 2012 It not even on all of them anyway is it? Isn't it (mostly) only for US, Japan and Aussie? my E39 doesn't have EGR or the pump, from factory. Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted November 30, 2012 What a lazy mechanic.Ha's a very good mechanic,he just said there's no point spending $$$$ on a part you don't need, ask your mechanic if the part is needed if he say's yes then maybe you should change mechanics Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted November 30, 2012 It's on for thirty seconds whe the engine is stone cold, it pumps air into the exhaust syytem, it does not require to be there. Remove and throw away. If they work then leave them be. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 1, 2012 It not even on all of them anyway is it? Isn't it (mostly) only for US, Japan and Aussie? my E39 doesn't have EGR or the pump, from factory. Our NZ 330i doesn't, but the NZ 540 does. shrugs Bin it. Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted December 1, 2012 It's on for thirty seconds whe the engine is stone cold, it pumps air into the exhaust syytem, it does not require to be there. Remove and throw away. If they work then leave them be.Thanks Greg i will take your advice on this one, just don't understand why the mechanics and parts people on site want to sell me something i don't need :lol: cheers have a good weekend Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted December 1, 2012 I disconnected pump last night drove to work today,about 1hr drive in total on open roads checking fuel usage and it stayed the same,performance seemed a little better or maybe it was just in my head sweeeeeeeeeeeeeeeeeet. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted December 1, 2012 In your head. Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted December 1, 2012 yeah in my head Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted December 1, 2012 Does it trigger a CEL light when it's removed/non-functional? Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted December 1, 2012 Does it trigger a CEL light when it's removed/non-functional?no warning lights came on. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted December 1, 2012 No it won't, it's simply an air pump for emissions. Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted December 1, 2012 No it won't, it's simply an air pump for emissions. I'm aware of that... the reason I asked is that the CEL is designed to monitor the emissions system, or rather the systems of the car that keep it running with the lowest possible emissions. At least that's what my manual leads me to believe. I just find it strange that they wouldn't connect this pump to the system which monitors everything, perhaps because it was not market specific. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted December 1, 2012 It seems it bypasses all that, it pumps air into the system to burn off all the excess gas, the 02 sensors are constantly reading and adjusting. Quote Share this post Link to post Share on other sites
vendt 1 Report post Posted December 2, 2012 It seems it bypasses all that, it pumps air into the system to burn off all the excess gas, the 02 sensors are constantly reading and adjusting.hi greg your ganna hate this question,but what do i do with the holes where the secondary valve goes?cheers Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted December 2, 2012 Just block them up. Quote Share this post Link to post Share on other sites
