e30ftw
e36 window switches and wiring
After 4 e36 window switches with the little flat rectangle surrounds, also the plugs for them and cut off some of the wiring,
As below picture.
As below picture.
Two, four?
I need 4, but picture showing what I need like what kind of surround and the plugs with some wiring..
above are the blue digital switches ... Are us trying to use this on an E30 ? if so you need white bottom switches. which is actually a switch, not a digital encoder.
If not disreguard :D
Will see if we have white bottom ones avaliable.
Ahh yup exactly it. I took that screenshot of one of the writeups for the swap lol.
Cheers greg let me know.
BUMP.. Still looking for some, with the white bottom connectors.
Just give Ray a call. Got mine from him. Cheap as chips too.
BUMP..
Got some, with the white digital connectors......................
Anyone got the proper ones...? I've even modified my console so I now have the e36 surrounds and e30 switches just hanging out all over the place.. ugh.
