E30320i 1 Report post Posted March 21, 2013 Hi guys Just bought some new wheels and was planning on using the new wheel nuts that came free with the wheels to change the Lug bolts on my BMW E30 into wheel nuts. Was thinking that you could buy 16 bolts the same diameter and length and make them permanently stay in the hub? Any Ideas? Was Just wondering if anyone has done this on here? Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted March 21, 2013 Ive got some 20mm spacers with wheel studs if you want those? Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted March 21, 2013 You need to use proper wheel studs, designed for that purpose. RRT, Vorshlag, Turner and Bimmerworld all do stud conversion kits that screw in place of your wheel bolts. Also pay to double check this isn't a WoF or LVVTA cert. issue, as you are altering how the wheels are attached. Alternative is to remove all the hubs from the car and have the hubs drilled out and pressed in studs inserted. Not the best solution, if you replace a front wheel bearing on an E30, you'll need to drill out and insert new studs into the new hubs..... Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted March 21, 2013 Do they not have center caps that would cover them anyway? Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted March 21, 2013 use thread locker and buy studs from reputable company. if you want bling, spray paint dem OEM nuts Quote Share this post Link to post Share on other sites
E30320i 1 Report post Posted March 21, 2013 yeah thats what i was thinking, something along the line of that thread locker. It would be better to do it properly and see if it is actually legal, as a half ass job could end up being potentially dangerous maybe? and the centre caps, i didnt really like them so probably wont use them really a. Ill do some more research and see if its safe and legal Cheers guys, Any questions or advice. ask away Quote Share this post Link to post Share on other sites
E30320i 1 Report post Posted March 21, 2013 http://www.vorshlag.com/product_info.php?c...products_id=120 I found these, which seem to be the best, BUT, all the wheel nuts the use with them are endless where as the wheel nuts i got with mine are not? Do you guys think this will still work? Cheers Quote Share this post Link to post Share on other sites
DarinD 8 Report post Posted March 21, 2013 http://www.vorshlag.com/product_info.php?c...products_id=120 I found these, which seem to be the best, BUT, all the wheel nuts the use with them are endless where as the wheel nuts i got with mine are not? Do you guys think this will still work? Cheers You could get the same thing over the counter at Davie Holden in Manukau... And the wheel nuts will fit if its 1.5 too. Im running a stud conversion on my e36 purely for ease of wheel removal and have had no issues. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted March 21, 2013 Ive had no issue removing and replacing BMW wheels ever... Surely you can buy blingy studs Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted March 22, 2013 I have shiny silver studs sitting on my workbench. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted March 22, 2013 http://www.vorshlag.com/product_info.php?c...products_id=120 I found these, which seem to be the best, BUT, all the wheel nuts the use with them are endless where as the wheel nuts i got with mine are not? Do you guys think this will still work? Cheers Those are the 90mm long competiton studs! You don't need those unless you need to run +30mm spacers, or bolt on some spinners and dice up pedestrians. Have a look at Bimmerworld, I'm sure they have nickle plated shorter replacement studs. Don't go half-arsed and buy generic 'studs' from the local fastening supplies store. Remember these are for holding your wheels on, and, more importatnly keeping other road users safe. Quote Share this post Link to post Share on other sites
