Lukeprusher 13 Report post Posted March 27, 2013 (edited) Not sure on engines want an engine transfer on my e30, as its a 316i quite slow. Edited March 27, 2013 by Luke Prusher Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 27, 2013 really depends on your budget. anything is possible if you throw enough money at it. many different engine swaps have been done . m50b25 m52b28 m60b40 m3 engines etc etc. v12's turbo m50's etc whats your budget??? Quote Share this post Link to post Share on other sites
Lukeprusher 13 Report post Posted March 27, 2013 My budget will be around 5000 for engine, manifolds etc. Cheers Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 27, 2013 My budget will be around 5000 for engine, manifolds etc. Cheers probaly a m50b25 or m52b28 Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 27, 2013 go for a 3.5 straight six from an e34 with that budget you can get a lot overhauled and mounts done plus cert and thats a lil beast when done Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 27, 2013 go for a 3.5 straight six from an e34 with that budget you can get a lot overhauled and mounts done plus cert and thats a lil beast when doneyes good option too , but manual gearboxes/flywheels to suit are a bit harder to find. Quote Share this post Link to post Share on other sites
Lukeprusher 13 Report post Posted March 28, 2013 Is the m60B40 a good choice? 210kw and 286hp? Would this be expensive? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted March 28, 2013 (edited) For a manual, yes. From what I remember you'd need custom mounts etc, You can do a m52b28 swap bolt straight in with the right parts. Only custom work is the wiring adapter (easily find a wiring diagram) and the exhaust. Then spend what you have left on the motor like OBD1 swap or suspension, cert etc... Edited March 28, 2013 by e30ftw Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted March 28, 2013 Keep in mind you would have to overhaul suspension, upgrade diff size, brakes and driveshaft with a 316i base. a M50B25 or M52B28 would be an ideal upgrade, expensive enough to do as is. V8 Conversions, 10k+ minium if your to do it properly, better off to just by a 540i in most cases. Most used M60s would need an overhaul of a varying degree anyway, but the same can be said for all 15-20 year old donor engines. Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted March 28, 2013 Can do M20 2.8 strokers or M50 3 litre strokers within your Budget. We have M60,M62 motors avaliable that along with 6 spd manual would be more $$. Call for details. Quote Share this post Link to post Share on other sites
