Lukeprusher
E30 Engine swap
Not sure on engines want an engine transfer on my e30, as its a 316i quite slow.
Edited by Luke Prusher
really depends on your budget. anything is possible if you throw enough money at it.
many different engine swaps have been done .
m50b25
m52b28
m60b40
m3 engines etc etc.
v12's
turbo m50's etc
whats your budget???
My budget will be around 5000 for engine, manifolds etc.
probaly a m50b25 or m52b28
go for a 3.5 straight six from an e34 with that budget you can get a lot overhauled and mounts done plus cert and thats a lil beast when done
yes good option too , but manual gearboxes/flywheels to suit are a bit harder to find.
Is the m60B40 a good choice? 210kw and 286hp?
Would this be expensive?
For a manual, yes. From what I remember you'd need custom mounts etc,
You can do a m52b28 swap bolt straight in with the right parts. Only custom work is the wiring adapter (easily find a wiring diagram) and the exhaust.
Then spend what you have left on the motor like OBD1 swap or suspension, cert etc...
Edited by e30ftw
Keep in mind you would have to overhaul suspension, upgrade diff size, brakes and driveshaft with a 316i base.
a M50B25 or M52B28 would be an ideal upgrade, expensive enough to do as is.
V8 Conversions, 10k+ minium if your to do it properly, better off to just by a 540i in most cases. Most used M60s would need an overhaul of a varying degree anyway, but the same can be said for all 15-20 year old donor engines.
Can do M20 2.8 strokers or M50 3 litre strokers within your Budget.
We have M60,M62 motors avaliable that along with 6 spd manual would be more $$.
Call for details.
