JohnM575 107 Report post Posted April 25, 2013 (edited) As per the title, I was wondering if someone on here has an Z3 gear lever (and bushings) and ZHP 5 Speed gear knob. The gear change currently has a fair amount of "play", and the gear knob leather has worn through and is looking worse for wear and I am after a knob with a bit more weight to it. I understand the play may be due to wear and tear internally, but I am keen to see if the new lever reduces that sloppy feel as many people seem to report an improvement when changing the shifter bushings. Also I would be looking for install for the Z3 lever (or equivalent) if possible. HellBM? Anyone else stock these parts? Edited April 25, 2013 by JohnM575 Quote Share this post Link to post Share on other sites
HELLBM 1531 Report post Posted April 25, 2013 Can do short shift supply/install. Quote Share this post Link to post Share on other sites
swordfish 30 Report post Posted April 25, 2013 (edited) I have a Z3 Roadster selector rod, ZHP 5 speed Gear Knob and brand new bushes all around on my M3! I love the feel of the gear changes! It’s perfect, not too short, and not too long. Just perfect! No play either. But I guess this is due to new bushes as well. The entire installation is very easy, would take 3-4 hours in home setting, without taking a driveshaft off. Edited April 25, 2013 by swordfish Quote Share this post Link to post Share on other sites
swordfish 30 Report post Posted April 25, 2013 Oh, I forgot! Z3M roadster rod has to be bent two ways to be in the upright position inside the car. Quote Share this post Link to post Share on other sites
