Markw336 0 Report post Posted May 11, 2013 hi all i have recently aquired an 1988 320i beemer and ive noticed it was a little bit slow for the size of the motor and my dad has pointed out to me thats its the timing because its also quite hard to start which also leads me to think that hes right it has an m20b20 motor i cant seem to find much on it so if anyone knows how to it would be greatly appreciated on the knowledge on how to adjust the timing Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 11, 2013 Being 88 - is it a pre facelift (chrome bumper) or F/L car? If pre - has a distributor on LH side of engine to adjust timing in usual manner. If F/L car - it is Motronic which is full engine management & ign timing is controlled by ECU Quote Share this post Link to post Share on other sites
Markw336 0 Report post Posted May 11, 2013 ok well it apears to be a facelift as it has a plastic bumper and what i thought was the dizy isnt as the leads go in sideways so with this being the case what would cause the car to run retarded timing other then the timing belt not being put on properly even tho i have idea when it was last replaced Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted May 12, 2013 I'd do the timing belt, and check it's on right. They need to be done every 4-5 years, regardless of milage, and the milage varies, but I wouldn't leave it to 100K. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 12, 2013 ok well it apears to be a facelift as it has a plastic bumper and what i thought was the dizy isnt as the leads go in sideways so with this being the case what would cause the car to run retarded timing other then the timing belt not being put on properly even tho i have idea when it was last replaced The unit in the front at the end of the cam is the distributor, but that's all it does - distribute HT spark. The timing controlled by the ECU. As above - first check that cam timing is correct, if unsure of it's age - replace it Quote Share this post Link to post Share on other sites
RAH 6 Report post Posted May 12, 2013 I'd do the timing belt, and check it's on right. They need to be done every 4-5 years, regardless of milage, and the milage varies, but I wouldn't leave it to 100K. I 2nd this. Its probably 1 tooth out and while you are there put a new one on Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 12, 2013 They come slow like that from the factory. Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted May 12, 2013 They come slow like that from the factory. I thought I already replied to this thread and said this - If it's a 2.0 auto, they are slow! Quote Share this post Link to post Share on other sites
Markw336 0 Report post Posted May 12, 2013 i still dont think it should be as slow as it is plus its hard to start and idles rough after starting for a few seconds then comes right also the plugs and leads are new but im buying a timing kit and water pump tomoro but going to check the timing tomoro after work Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 12, 2013 check for vac leaks , bad icv , worn out afm , worn out dizzy and rotor , worn plugs , dirty air filter , stuffed fuel pressure reg , do a compression check. and yes the 320i auto are a bit slow off the mark , tall gearing and rev happy top end power , but not much torque down low. bring it around if you want me to look at it [email protected] papakura 021433600 Quote Share this post Link to post Share on other sites
Markw336 0 Report post Posted May 13, 2013 ok so i took it to a mechanic and we couldnt find the timing lines on the motor so we didnt do that but he took it for a drive and had a thought the torque converter might be playing up and then we chucked a scanner on it and it had the ekp relay code on it from doing a little bit of research that appears to be the fuel pump relay so probally going to pull the timing covers off tomoro and have a look Quote Share this post Link to post Share on other sites
Markw336 0 Report post Posted May 15, 2013 ok so ive done the timing now the old belt was 1 tooth out and the tensioner was making a light bearing noise, i also replaced the viscous fan and the squealy belt so now the car runs and sounds a thousands times better still seems to take a bit to start but starts slightly easier Quote Share this post Link to post Share on other sites
RAH 6 Report post Posted May 15, 2013 ok so ive done the timing now the old belt was 1 tooth out and the tensioner was making a light bearing noise, i also replaced the viscous fan and the squealy belt so now the car runs and sounds a thousands times better still seems to take a bit to start but starts slightly easier told ya Quote Share this post Link to post Share on other sites
Allanw 1080 Report post Posted May 16, 2013 Result! Quote Share this post Link to post Share on other sites
