Arma 134 Report post Posted July 6, 2013 (edited) Another little, and hopefully not big, problem. This is for my 2001 e39 530i Just noticed something, and it's something I did not notice a few days ago - and I don't think it was noticed when I was having my new cooling parts installed last week: The hose coming out from under my ATF fluid reservoir is leaking fluid. I think it is the power steering hose, but I may be wrong. After taking a closer look at it I've noticed that the clamps on both of the hoses that come from under the reservoir have come off / snapped (see photos). Googling it seems like others have come across this issue a fair bit before. Question is, how could BOTH clamps have snapped/come off and fluid started leaking so much in the last few days? There is a fair amount of fluid/oil under the engine bay (where the guard is), and there seems to be some oil all around the area of the reservoir as well - e.g. on the intake manifold there is oiliness on the side - was wondering whether this could have been caused by some belt or fan spraying the leaking oil onto the manifold? My main questions, however, are: Is this likely to be a 'Get new clamps' job, or is it best to get new hoses? How difficult (time-wise) is the job, for a mechanic? Is it safe to drive the car to the workshop; distance will be ~3.5km? Have garaged the car and am driving my 520i around atm - didn't want to risk driving the 530i with the leaking fluid... (On another note, the 520i disa valve died zzz ) Anyway, here are some photos: The hose that's leaking. I think the one next to it is leaking too. Can see the clamps are not closed. And also, what appears to be, some oil on the intake manifold. Can see the clamp loose here too. Is this the power steering hose? Dampness / oil on the intake manifold. How'd that get there? Edited July 6, 2013 by Arma Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 6, 2013 (edited) Those clamps havent broken. Your just seeing the tail of the clamp. Try tightening them and just check the power steering resevoir fluid level. And yes, they are both power steering hoses. One is a return (the smaller one) and the other is the pump supply hose. Edited July 6, 2013 by *Glenn* Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted July 6, 2013 These could have been tightened and area cleaned in 1/2 the time it that it took to post this topic.... Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted July 6, 2013 M3 had the same problem, pretty common on all e36s and e39s I'm guessing. Like Ray said, a pretty simple task. I was replacing the fluid when I did mine but just get a big sirenge and suck up the fluid in the resivour, unbolt it to make life easier to remove clamps, and hoses, suck abit of fluid from them so you don't spill it everywhere, give hose inners a wipe with brake clean and the bits on the bottom of the resivour. I used a wee smear or atv silicone to give it a good seal then put hoses back on with new clamps, cleaned all the leaked fluid off everything then bolt back in and top up fluid. Job done! Quote Share this post Link to post Share on other sites
allan 295 Report post Posted July 6, 2013 Hi, replace the "O"ring in the power steering reservoir cap these get flattened by people over tightening them repeatedly. The reservoir hoses go hard over time, engine heat etc if you have enough hose cut the hard end off and re clamp them if not replace the hoses. Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted July 7, 2013 Those clamps havent broken. Your just seeing the tail of the clamp. Try tightening them and just check the power steering resevoir fluid level. And yes, they are both power steering hoses. One is a return (the smaller one) and the other is the pump supply hose. Ah right. I'll try tightening + checking fluid level once I'm back at the old house today. I might bring it to you early morning tomorrow if things don't look good / I'm unsure.These could have been tightened and area cleaned in 1/2 the time it that it took to post this topic....Had to get back to my city place in a rush last night, so only managed to snap a few photos before leaving the car at my old garage. Though I must admit I'm scared I'll get p/s fluid everywhere if I play with the hoses!Cheers guys Quote Share this post Link to post Share on other sites
