jake1829 119 Report post Posted August 26, 2013 Hi Am looking to change my suspension to a coilover set - anyone put in KW V3 or ridden in a car with a set? Anyone had issues with KW coilover set? thanks Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted August 26, 2013 Hi Am looking to change my suspension to a coilover set - anyone put in KW V3 or ridden in a car with a set? Anyone had issues with KW coilover set? thanks easy4life has some V2s in his E46 M3 Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted August 26, 2013 Have a read through CSet's thread before deciding. Although it's for a E46 M3 I learnt more from this thread on coilovers than looking through overseas forums. http://www.bimmersport.co.nz/forums/index....l=pss9&st=0 Quote Share this post Link to post Share on other sites
jake1829 119 Report post Posted August 26, 2013 Have a read through CSet's thread before deciding. Although it's for a E46 M3 I learnt more from this thread on coilovers than looking through overseas forums. http://www.bimmersport.co.nz/forums/index....l=pss9&st=0 thanks Neal, looks like some good info there to ponder Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted August 26, 2013 Hi Jake Still recommend autoquip for KW, have been running them this year and they are fantastic quality. If you have the money, buying a set of V3's is probably the easiest option, spray and walk away handling upgrade. I will be my normally trolling self and say I would be looking at that LSD first though, your car with a LSD at a trackday would be mucho funno! Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted August 26, 2013 I got some of my old e46/330 posts around here somewhere ... I would say that v2/3s are about the same firmness as the hardest rate stock motorsport suspension with the added benefit of adjustible ride height. I rane with 19 inch wheels and uprated eibach sway bars and the v2 setup for many years.. was good Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted August 26, 2013 That car cornered flat and fast! Quote Share this post Link to post Share on other sites
jake1829 119 Report post Posted August 27, 2013 (edited) Hi Jake Still recommend autoquip for KW, have been running them this year and they are fantastic quality. If you have the money, buying a set of V3's is probably the easiest option, spray and walk away handling upgrade. I will be my normally trolling self and say I would be looking at that LSD first though, your car with a LSD at a trackday would be mucho funno! Good to know you're happy , ya i saw Chris@autoquip yesterday - his prices were def on par Ya im pretty much going to go with V3 - only thing i need to check if they fixed the squeaky sound issue - seems back in 2010/11 the V3's that were installed on the 335's - lots of people were complaining def want to drop the ride height a bit- LSD is right up there after the suspension - Edited August 27, 2013 by jake Quote Share this post Link to post Share on other sites
jake1829 119 Report post Posted September 6, 2013 KW V3's arrived this arvo, now to get them fitted Quote Share this post Link to post Share on other sites
