Joost 0 Report post Posted November 14, 2013 Hi Guys, Just had my Bimmer for 6 weeks and notice that when I start it up the yellow oil sensor light comes on when I start driving. It stays on for about 15 seconds and then flicks off. I've checked the oil level and its three quarters full. It sounds like a broken oil level sensor to me, Do you guys concur? Is it worthwhile replacing it? Car has just been serviced and its only used as a weekend driver Appreciate your feddback Cheers J Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted November 14, 2013 Sounds just like mine. Yellow (I think) indicates the sensor is duff, or perhaps not working correctly. Of course, there is something in the engine bay called a dipstick which can be used. Change it out when you next change the oil. If your car has a few miles on it, get a sump gasket too, and drop the oil, remove the sump, clean, replace sensor (with new O-ring; genuine BMW ones have an O-ring, as do Hella, but the Meyle ones might not) and refit. Carefully. Don't overtighten the sump bolts. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 14, 2013 comon fault on e46 e39 etc have some if needed [email protected] Quote Share this post Link to post Share on other sites
Joost 0 Report post Posted November 15, 2013 Thanks Guys, Have been checking the oil level weekly and it seems fine- not full but no noticeable change in level. I do check it when engine at operating temp as per manual recommendations Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted November 15, 2013 My 2c... Remember that the oil light / sensor actually measures oil pressure, hence if it lights up it should be checked and rectified immediately to avoid larger issues. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 15, 2013 My 2c... Remember that the oil light / sensor actually measures oil pressure, hence if it lights up it should be checked and rectified immediately to avoid larger issues. No it doesn't on a E46... Orange oil can is oil level.... Red oil can is no oil pressure Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted November 15, 2013 (edited) No it doesn't on a E46... Orange oil can is oil level.... Red oil can is no oil pressure Thanks - learnt something new today. Stuck in the 80's. Edited November 15, 2013 by C-130 Hercules Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted November 18, 2013 No it doesn't on a E46... Orange oil can is oil level.... Red oil can is no oil pressure Thanks - learnt something new today. Stuck in the 80's. Yup - the 15 seconds of orange oil light after starting the engine refers specifically to the sensor failing, or having failed. At other times, an orange oil light indicates low oil. A red oil light, at any time, indicates low or no oil pressure. This is measured by a completely different sensor system. Think of the in-sump sensor as an inverted dipstick. All it does is check there is oil present. Yes - it is a good idea to get it sorted, but provided you check your oil level regularly in the traditional way (just like you would on any car) then you're unlikely to have a problem. Quote Share this post Link to post Share on other sites
