YU4562
E30 Antenna Delete
since I bought my e30 last year, i've been really eager on removing the universal type antenna installed as it doesn't retract and it's not fitted properly but i can't find an original replacement(second-hand of-course). I don't listen that much on AM/FM so the replacement is just for cosmetics, I've seen a couple but they're always missing the important bits. After checking forums I decided to just go with rubber plugs. it took me a while but I was finally able to get an alternative from Supercheap.
1" blank grommet, it's a tad bigger than what i need as antenna hole is ≈22MM(7/8" will be a better fit) but it's the only size available in the store
here's how it sits now
Had thoughts of using the e36 antenna system as it uses the chassis as an Arial that way you can delete stock one as you have done but still use the radio
I think I have an original replacement if you still want one
