satianv 0 Report post Posted October 26, 2005 Has anyone else come across this ...With the key turned off and the door open, the power window should work but my old E30 318 1989 doesn't seem to like doing it... Suggestions anyone?...Thanks. :jap: Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted October 26, 2005 Umm there not supposed to work. Once you turn off the key and/or take out the key and open the door the windows stop functioning ... But if you turn off the car and don't open the door they remain usable for a certain amount of time ... Quote Share this post Link to post Share on other sites
DCEIVN 0 Report post Posted October 26, 2005 Neh thats not true, the as far as I know the E30 E28 and even E34 you are able to use the windows after you take out the key and open the door - but not if you close it I don't think. Never knew why they were designed that way though - I thought just so you could close the window after you take the key out in case. Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted October 26, 2005 In my E36 and E46 i could take out the key and the windows still closed, however as soon as i open the doors they would stop working ... Quote Share this post Link to post Share on other sites
gmccormack 0 Report post Posted October 26, 2005 Do your interior lights come on when you open the door in question? Are all the windows effected? Does opening one of the other doors get them working? Quote Share this post Link to post Share on other sites
topless 13 Report post Posted October 26, 2005 Pre f/l e30's are wired differently to f/l. The door open/window working with ignition off only functions in the pre f/l. It is a simple job to change it in f/l models to work like the pre f/l models. You will need to locate the relay under the cubby and remove the switched power and replace with a permanent power source (which can be found in the large white terminal block in the same area). The main cause of it not working in cars wired for it is the door switch is not making earth contact. The switch has two contacts, one for the interior light, the other for the window relay, and both don't make proper contact. Just clean the contacts and wire the two points together. Quote Share this post Link to post Share on other sites
Nic325i 0 Report post Posted October 26, 2005 The door open/window working with ignition off only functions in the pre f/l Mine is post f/l, has this function - not sure if it has been modified or not. Quote Share this post Link to post Share on other sites
speedyg 19 Report post Posted October 26, 2005 Both my old pre F/L and my F/L had this feature. Have a look at this site, there is an article under the electrical section. www.bimmerdiy.com/e30 Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted October 26, 2005 Mine is post f/l, has this function - not sure if it has been modified or not. Same her, mine is facelift, and has this feature.Essentially it is just the switch located in the door jam at the front of the door (near the hinges from memory). As suggested take the switch out, clean up the contacts, and it should be fine (I have had to do this on both sides at one time or another). Cheers Grant Quote Share this post Link to post Share on other sites
satianv 0 Report post Posted October 27, 2005 Thanks guys..will try it our over the weekend. Quote Share this post Link to post Share on other sites
topless 13 Report post Posted October 27, 2005 I had to change the wiring in f/l I have now as it would only work with the key on but obviously seems this might be an oddity, so the most likely culprit would be the door switch. My cab had a faulty door switch... My bad... Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted October 27, 2005 (edited) once the door is open past a certain degree the windows do open and shut. My one does do this. Edited October 27, 2005 by E30stz Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 27, 2005 mine are fully finctional on my facelift, but one thing do you have the switch that turns them on and off? as the wires can pull out of these easily, just plug them back in and you might be alright. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 27, 2005 Another f/l another one that works but only on the drivers door I think? Ali - you seriusly need to consider upgrading your car to an E30 for this must have feature!!!! I'm sure someone here will begrudgingly swap you if you plead with them. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 28, 2005 Another f/l another one that works but only on the drivers door I think? Ali - you seriusly need to consider upgrading your car to an E30 for this must have feature!!!! I'm sure someone here will begrudgingly swap you if you plead with them. haha yeah ali you need to upgrade man!!! mine works on both windows?? maybe it was done before i got it?? Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted October 28, 2005 So in the E30 after you open the doors the windows still goes up and down ?? Oh well doesn't matter .. I can just use the remote to close it as i walk away anyway .. hehehe ... The only car i would consider swapping for in the E30 style is an Mint M3 Evo III .. heheheh .. anyone wanna swap ?? Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted October 28, 2005 (edited) sorry, all I heard was "Rich Plonker" ... can you say again ? Edited October 28, 2005 by E30stz Quote Share this post Link to post Share on other sites
aliluya 0 Report post Posted October 29, 2005 Say wha ? Quote Share this post Link to post Share on other sites
satianv 0 Report post Posted November 6, 2005 Been to the link below, can anyone help me to interpret it to "A power window fix for the dummies" version of it. http://www.bmwe30.net/cgi-bin/datacgi/data...0051&Section=02 Thanks. PS: My door switches are cleaned and confirmed to be working fine..... Quote Share this post Link to post Share on other sites
satianv 0 Report post Posted November 8, 2005 Anyone with ideas....? Beers to be claimed for acceptable answers. :bowdown: Quote Share this post Link to post Share on other sites
