hugokan 0 Report post Posted May 7, 2014 (edited) Hi guysWanting a Red Label Bosch 0261200413 DME. Also wondering whether a Silver label 413 DME (presumably with ews) will work as well. It should have no immobiliser to communicate with? Thanks Hugo Edited May 13, 2014 by hugokan Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted May 7, 2014 Hi, I recently replaced the ecu in our 323 it cost 300 including the ews and key. if they change the ecu ews may be a problem Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 7, 2014 Hi, I recently replaced the ecu in our 323 it cost 300 including the ews and key. if they change the ecu ews may be a problem dont you mean.. ecu kit including the ews box and ews chip from the key Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted May 7, 2014 no way do you have to pay that 900 if you didn't actually ask them to do anything with it Quote Share this post Link to post Share on other sites
hugokan 0 Report post Posted May 13, 2014 First post updated Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted May 13, 2014 Ecu's are unique to the corresponding engines mixing them could cause problems as timing, injection etc is effected and could damage component's. Its best to get the correct ecu and ews. Short of that if you have key chip and matching ews module I believe you can sync the ews with the ecu with a scan tool. You should contact brent from the comments above. Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted May 14, 2014 We have a 413 dme here off of a 325 make a offer Quote Share this post Link to post Share on other sites
