nz320i 0 Report post Posted October 29, 2005 (edited) hey got a 2L M20 and want to put another head with lower k's on it with port and polished, dont want a 2.5 for petrol as im too cheap and happy with the 2L is it expensive to do and can you do most of the work at home? maybe get a cam as well..so harder valve springs?? what are some good options and costs does anyone know? cheers- next years project Edited October 29, 2005 by nz320i Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted October 29, 2005 Don't know why, but when the mexhanic I use put a different year head on a 320, it wouldn't run properly, kept missing. After lots of head scratching and consultation with other Bimmer mechanics, he changed it for the same year head and away it went. Something to watch out for. Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted October 29, 2005 not worth doin it to a 2ltr bro, and by the time u do those mods it'll be uneconomical as anyway.... u'll end up spendin prolly 5g+ as well, and a 325 will still kick ur arse. put a m50 in Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 30, 2005 sweet as, i just want to get it a little quicker, what mods can i do apart from induction? and exaust i mean like ive been told a new coil is good with soem new leads and good spark plugs?? Quote Share this post Link to post Share on other sites
bmwsparkle 3 Report post Posted October 30, 2005 do some headers, no matter what people tell you, bmw standard exhaust manifolds suck. And that way u can swap over if you put a 2.5 or 2.7 in (pretty sure they'd fit) Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted October 31, 2005 323i head will do nicely. but i dont think it will work with the motronic engine. but then again there is no reason why it wouldnt. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted October 31, 2005 but i dont think it will work with the motronic engine. but then again there is no reason why it wouldnt. it does Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted October 31, 2005 The most life-changing thing you can do with an M20B20 is stick a manual gearbox on it, which you've done. Keep the engine well maintained, and it will serve you well. I wouldn't replace anything unless the old bits were rooted.. Money is better spent on a M20B25 or M50... M50B25 would be fairly good on the petroleum wouldn't it, compared to the M20B25? Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted October 31, 2005 The most life-changing thing you can do with an M20B20 is stick a manual gearbox on it, which you've done. Keep the engine well maintained, and it will serve you well. I wouldn't replace anything unless the old bits were rooted.. Money is better spent on a M20B25 or M50... M50B25 would be fairly good on the petroleum wouldn't it, compared to the M20B25? Then again you could be even more sensible and buy a toyota. Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted October 31, 2005 Money is better spent on a M20B25 or M50... M50B25 would be fairly good on the petroleum wouldn't it, compared to the M20B25? Then again you could be even more sensible and buy a toyota. so true, ae86!!!! i just watched the funniest car dvd, Hot Version, its mostly sub titles as its japanese but pretty cool aye. I think ill give my engine a bit of tlc and see how it runs the tappets are a littl bit noisy and i have a funny idle. Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted October 31, 2005 Don't worry about the funny idle, If done right you can pull off the just "lumpy cams' thats why the idle's sh*t" Temp sensor out? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted October 31, 2005 Stick in a 325 throttle body first and see how you like that, it's a good cheap mod and will yield decent results Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted November 1, 2005 Never heard of the 325i throttle body Mod - what sort of results from this are to be expected? Would be interested to find out - Cheers Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted November 1, 2005 Don't worry about the funny idle, If done right you can pull off the just "lumpy cams' thats why the idle's sh*t" Temp sensor out? i think i could alsmost pull off its got a 12a bridg port rotor when its cold and a lumpy cam when warmish LOLumm temp sensor??? why would this matter? as it could be, is that the thing in the coolant resivour as i think it is a bit iffy Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted November 1, 2005 Stick in a 325 throttle body first and see how you like that, it's a good cheap mod and will yield decent results ok might consider that, as it will be next year so ill put some cash aside for a few things for the engine, it needs a bit of work i think im not really sure though, when i took it to a bmw guy last time he put hs computer on it and said it was fine??? Quote Share this post Link to post Share on other sites
