e30ftw 435 Report post Posted June 30, 2014 -Alias- owns a set of cam alignment tools if you need, I have them at the moment but haven't got around to using them cos camshafts look like a pain in the ass. Quote Share this post Link to post Share on other sites
slideways 53 Report post Posted June 30, 2014 -Alias- owns a set of cam alignment tools if you need, I have them at the moment but haven't got around to using them cos camshafts look like a pain in the ass. Sweet cheers dude, I will keep him in mind. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted June 30, 2014 Brent means to pump kero through the lifters to clean them. even with no plugs will a starter last that long? Pick-a-part Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted July 1, 2014 While it's out and you haven't sunk much into it you may as well pull it apart IMO. There's a good chunk of cash you haven't thrown at it simply for the price you paid for it. Rings, bearings, gasket set, and a good look at the head itself wouldn't go amiss or set you back that much either I wouldn't imagine. I'd take shortcuts on an engine I knew about, I'd tend to be more cautious on one I'd never seen running though. If I intended to keep it and use it I'd want piece of mind knowing it's going to last before I took the time and effort to swap it into something. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted July 2, 2014 While it's out and you haven't sunk much into it you may as well pull it apart IMO. There's a good chunk of cash you haven't thrown at it simply for the price you paid for it. Rings, bearings, gasket set, and a good look at the head itself wouldn't go amiss or set you back that much either I wouldn't imagine. I'd take shortcuts on an engine I knew about, I'd tend to be more cautious on one I'd never seen running though. If I intended to keep it and use it I'd want piece of mind knowing it's going to last before I took the time and effort to swap it into something. Bigger that. Just start it Quote Share this post Link to post Share on other sites
