trottsky 24 Report post Posted October 29, 2014 Does anybody know where to get hold of a sump guard for an e36 328 coupe? I saw one on ebay a while ago in the uk but can't find it anymore, also for obvious reasons it would be easier to get hold of one from over here. Or is it the kind of thing you'd have to fabricate yourself due to not much demand? I'm going on a South Island roadtrip in January and the front end is a little low, I REALLY don't want to smash the sump up in the Haast pass or anything : s Thanks, Tom Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 29, 2014 Going from memory you'd need to smash a bit of subframe and steering rack before you bottom out the sump. You might be thinking of an xbrace Quote Share this post Link to post Share on other sites
trottsky 24 Report post Posted October 30, 2014 Well judging by a certain m5 that came into work the other day with a smashed sump (after it had hit the subframe and rack infront of it), I wouldn't rule any scenario out. Cheers though Quote Share this post Link to post Share on other sites
pldubs 308 Report post Posted October 30, 2014 Just be careful ? Its pretty hard to break a sump ( even though ive f**ked 2 ) Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 30, 2014 Have an e46 guard but probably not much use, would need some sortta adapting. Pretty heavy too. Quote Share this post Link to post Share on other sites
trottsky 24 Report post Posted October 30, 2014 Ha, right ok well I might get an xbrace off of a convertible or something (don't know if they fit onto a coupe, will do some research) and then bash up some 4mm Alu plate Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 30, 2014 Ha, right ok well I might get an xbrace off of a convertible or something (don't know if they fit onto a coupe, will do some research) and then bash up some 4mm Alu plate Z3 crossbrace is the same as M3. Not overly cheap but, worth the investment from those I know that have fitted them Quote Share this post Link to post Share on other sites
trottsky 24 Report post Posted October 30, 2014 Z3 crossbrace is the same as M3. Not overly cheap but, worth the investment from those I know that have fitted them Cheers bro! Quote Share this post Link to post Share on other sites
