vtgts300kw 90 Report post Posted December 29, 2014 Is it as hard as the US forums make out, or have they got a different layout due to LHD? I need to replace mine, and if its easy "enough" to do myself, I'd rather take the money I'd spend on having someone else do it, and start buying quality tools. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted December 29, 2014 It's not hard, just a pain in the ass. Especially if you have torx head bolts. Just remove the intake boot and all that stuff and you should be able to get an extension bar with a socket on the bolt end easily. I try to drop a ring spanner on the back side nut from the top against the firewall, the lower one can be done from underneath. 1 Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted December 29, 2014 Get a mate with skinny arms and 3 elbows to do it. Put a new or rebuilt one in - if you're using second hand, you may have to do it again Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted December 29, 2014 As above, it's not a complex job, just difficult to get to. If you have a good socket set with wobble joints and extensions, etc then you have all the tools you need. Room to jack the front to get underneath is also helpful - saves the back strain of keep leaning over the front guard. Quote Share this post Link to post Share on other sites
vtgts300kw 90 Report post Posted December 29, 2014 (edited) Thanks for the replies, i might give it a go. Although I don't have the greatest of patience... Now where's the best place to get a starter? Edited December 29, 2014 by vtgts300kw 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 29, 2014 compared to my hiace which was 3 minutes out three minutes in and had it all done in 10 mins! takes longer than that to get the E30 in the air! Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 30, 2014 Adding to, the early type is a pain in the arse as it has the bigger yoke. The later reduction drive version is much more compact & easy to do. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted January 1, 2015 also if you have a manual trans it's less annoying to stick your arms around than an automatic trans Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 1, 2015 also if you have a manual trans it's less annoying to stick your arms around than an automatic trans Oh dear - I thought the manual was bad enough! - more reason for a skinny mate with skinny arms! Quote Share this post Link to post Share on other sites
