Filth 5 Report post Posted April 6, 2015 Hi guys, After a trip to Tauranga on the long weekend, my back left tail right has been doing some funky stuff... When I press on the brakes I get the reversing sound in the car ( gear will be in drive ). Error messages on the cluster "Check Brake Light" "Check Fog Light" etc etc... I've gone into the boot and played with the wiring, just moving around and I can get the light to work - So at least there is nothing wrong with the unit. Can anyone recommend a good local (Auckland CBD) auto sparky? I've called most places and they are booked up. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 6, 2015 probably a burnt out earth terminal to the light cluster Quote Share this post Link to post Share on other sites
Filth 5 Report post Posted April 6, 2015 probably a burnt out earth terminal to the light cluster So with that, I would need to replace the whole light? Quote Share this post Link to post Share on other sites
jeffbebe 1584 Report post Posted April 6, 2015 Doubt it. Just check the earths to each cluster and replace the damaged wire. Check the fuses as well. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 7, 2015 Make sure (when replacing wires) you use the correct gauge wire .. EG match the thickness of the metal part of the wire you're replacing. Quote Share this post Link to post Share on other sites
