kulgan 1042 Report post Posted May 4, 2015 Does anybody know where I can buy a decent sized detailers clay bar? The last one I bought was about the size of a block of butter and it's lasted me for years. Now all I can find is a block about the size of a very small bar of soap(same as the motels give ya) included with a lubrication spray all for the grand price of about 60 bucks. What a rip off. All I want is a decent sized block of clay. I dont want to buy so called lubrication spray with it.lol Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted May 4, 2015 (edited) Try a clay glove, they are meant to be way better. Or there are some cheaper bars here Edited May 4, 2015 by Nick G Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted May 8, 2015 The others seem to be 50 gram bars, like you say a small bar of soap. Pacer have 185 gram size, is this what you had? http://www.pacer.co.nz/shop/product_info.php?products_id=542 Id be in for a group buy if this is a good one? 12 @ $53 each Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted May 8, 2015 The others seem to be 50 gram bars, like you say a small bar of soap. Pacer have 185 gram size, is this what you had? http://www.pacer.co.nz/shop/product_info.php?products_id=542 Id be in for a group buy if this is a good one? 12 @ $53 each Count me in for a group buy Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted May 8, 2015 I wanted to have a go with clay bars but never used them before. Is it similar to very fine wet sanding (like 2000+ grit)? Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted May 8, 2015 (edited) I wanted to have a go with clay bars but never used them before. Is it similar to very fine wet sanding (like 2000+ grit)?Not really, like running putty over the car which feels kinda weird when you do it, great way to remove water spotting on surface and windows, needs some lubrication to work well, usually water spray.You tube it, not hard to do though Edited May 8, 2015 by Breaker Quote Share this post Link to post Share on other sites
kulgan 1042 Report post Posted May 9, 2015 Yeah, thats more like it. Good find. I'm in for a group buy. Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted May 10, 2015 Cool ok, your in! Ive got a group buy post on the for sale section Quote Share this post Link to post Share on other sites
CSET 602 Report post Posted May 11, 2015 We have a couple of different grades of clay bar available. See www.unitedcarcare.co.nz for more info. Only use blue grade if you're polishing afterwards, it's too heavy otherwise. If you just use water with clay you'll more often than not end up with a whole lot of residue. Best use a dedicated clay lube. Quote Share this post Link to post Share on other sites
