qube 3570 Report post Posted September 1, 2015 the little pockets on the bottom of the door card on my e36 came off again after fixing it with some glue last time. seems the glue isnt strong enough. the door pockets have the clips, so need the door pockets to be firmly attached to the door cards in order for the door card to attach to the actual door. any advice? Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 1, 2015 What type of glue did you use? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted September 1, 2015 ados i think, cant remember.. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted September 1, 2015 I did mine with araldite epoxy and they have lasted a couple of years so far. You need to scuff it with some 80 grit sandpaper, put heaps of glue on and leave it a week before you put them back in, but it works, i can't remember but i might have even put some fibreglass in there for good luck! It just means you have to drive around with no door cards for a while so dont park anywhere dodgy! Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted September 1, 2015 I always use urethane , sets like rubber sticks to everything. http://www.holdfast.co.nz/pages/product_details.aspx?pid=20054&cat=19&psid=20054 http://www.supercheapauto.co.nz/online-store/products/Sikaflex-Adhesive-227-310mL.aspx?pid=11079&menuFrom=1021364#Recommendations Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted September 1, 2015 cool thanks will give urethane a try Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted September 1, 2015 I've used a combo of builders glue, urethane, and a hot glue gun which holds it all together straight away to keep everything sitting tight while the other two go off. Has worked great so far on the top mounting piece of the door card on the m3 so far Quote Share this post Link to post Share on other sites
