Kepes 231 Report post Posted September 6, 2015 (edited) HelloMy current fan seems to have warped(?) or done something funny as it wobbles, intermittently hitting the hose going from the thermostat to the waterpump. Prefer close to Wellington so I can pick up tomorrow or tuesday, but if it can be posted quickly then happy to pay for that. New or second handpart # 11521271846 Or 11521273086 Real oem lists both for some reason.Pic. Part in question is number 1 Edited September 6, 2015 by Kepes Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2122 Report post Posted September 6, 2015 some are three bolt some are 4 bolt to connect to fan clutch so that will be the difference i would say Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted September 6, 2015 some are three bolt some are 4 bolt to connect to fan clutch so that will be the difference i would say Cheers Andy Mine is 4 bolt Quote Share this post Link to post Share on other sites
B.M.W Ltd 950 Report post Posted September 6, 2015 You sure it isn't the water pump bearing ?? Quote Share this post Link to post Share on other sites
Kepes 231 Report post Posted September 6, 2015 You sure it isn't the water pump bearing ?? Waterpump was replaced december 2014, so I assume hope it's still good Quote Share this post Link to post Share on other sites
WYZEUP 281 Report post Posted September 6, 2015 I might have one. Will look in the shed Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted September 6, 2015 Waterpump was replaced december 2014, so I assume hope it's still good Means nothing. I had an M52 E39 at work about 6 months back with a worn out pump. Fitted a Repco sourced GMB (Japanese but made in China) water pump to it. A week later I replaced it again due to it leaking. Upon removal, the bearing felt like sh*t! Second replacement has been fine. Quote Share this post Link to post Share on other sites
BM WORLD 1258 Report post Posted September 6, 2015 have new and used ones brent@bmworld.co.nz thanks Quote Share this post Link to post Share on other sites
