Jacko 2333 Report post Posted September 11, 2015 (edited) New toy has been treated with this stuff - http://www.tfgroup.co.nz/Articles/7.html Im guessing its pretty old now. Few swirl marks in the paint, gas station car wash maybe, nothing major, according the interwebs you'll never need to polish/wax car again, but it needs it - EDIT, actually, it was done 18 months ago Anyone know if the standard cut/polish compound (and wax) is OK to use on it? Edited September 11, 2015 by Jacko Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted September 12, 2015 Had a couple of cars with this on. Basically it does wear off after about three years. No problem waxing it though Clay bar it to remove whatever is loose and then do a normal polish and wax. I'd suggest if you've got swirls already it's likely warn out there anyway. I found this finish was Ok if you want a easy to clean not real glossy finish, good for a work car. Nothing like you can get with a good wax. Quote Share this post Link to post Share on other sites
Jacko 2333 Report post Posted September 12, 2015 Cheers Breaker, I ended up just dealing to it a like a normal finish and it worked shweet as, bit of polishing and then wax, minta. 1 Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted September 12, 2015 Nice, yip looks sharp. Nice shine Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted September 13, 2015 Do not cut it......if you cut the vehicle it will remove the coating and you will no longer be covered/voiding any paint protection Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted September 13, 2015 (edited) +1, even washing with a car wash solution can remove the coating. Meant to be washed with just water, or their own special wash solution. We use dura-seal at work, i dont rate it personally. If you want another coating put on, http://www.ocdetailing.co.nz/ are the guys to go to for C.Quartz. Edited September 13, 2015 by KwS 1 Quote Share this post Link to post Share on other sites
