WYZEUP 283 Report post Posted October 23, 2015 So in my silly haste to get this project well under way i didn't read properly into it, realising that i should have done a bit more reading first. I have come to the problem of ecu and wiring....now before i get too far im going to ask here on what people have done as there is no option for the 402 ecu with its small maf sensor, so what have you guys done with the ecu when it comes to getting a turbo conversion up and running? Looking round the place it seems the simplest option is to try and find a M50tu loom and 413 ecu with MAF and crank pulley etc.....or go direct wire in and tune that way? anyone used any other ways to get around this horrible system? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 24, 2015 Couldnt you just use a bigger maf and remap to suite. Actually all that time paying someone to calibrate it might not be worthwhileDoes the budget allow for a standalone ecu? Or one of those war chip things Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted October 24, 2015 War chip doesn't work with 402 ecu. Otherwise I would be using one. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 24, 2015 You can run a vanos ecu, need to change trigger wheel though and I believe can sensor needs to be changed. Just go stand alone, way more options and more control once you do. 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted October 24, 2015 Just go stand alone, way more options and more control once you do. ^ this Quote Share this post Link to post Share on other sites
Jibs05 86 Report post Posted October 28, 2015 or run a piggy back ecu like mapecu3. it will delete your maf anyway. 1 Quote Share this post Link to post Share on other sites
Red Dwarf 136 Report post Posted March 1, 2016 Is the MAPECU3 compatible with the M50/M52? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted March 3, 2016 Is the MAPECU3 compatible with the M50/M52? compatible with most ecu's Quote Share this post Link to post Share on other sites
