Shunty 0 Report post Posted November 4, 2015 I've put an M52B28 into my E36 Compact. The ABS is not working I have replace the diff and axles with medium case out of E30 325 When I fitted the axles there was a significant rubbing on the left side ABS sensor and the ABS didn't work. I replaced the sensor with one I had from a sedan I thought the issue was the instrument cluster from the 6 Cylinder donor car didn't power ABS but even with 4 Cylinder cluster in the ABS light comes on as soon as I start driving. And the ABS definitely isn't working (as discovered on a very wet Taupo track today!) Any ideas? Could the rubbing on the axle have damaged the axle so that the sensor can't read correctly? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 4, 2015 Scan it to see what fault comes up Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted November 4, 2015 You need to read the real time data from the ABS module to see the wheel speed data. This will quickly tell you if the module is receiving signal. Work from there. Next is valid CAN signal from the DME to the ABS Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted November 4, 2015 You need to read the real time data from the ABS module to see the wheel speed data. This will quickly tell you if the module is receiving signal. Work from there. Next is valid CAN signal from the DME to the ABS Yep meant scan/monitor live data - i should have been more specific. I remember my E39 having all the lights on & no fault codes Wasn't till I looked at live data & caught the R/H rear sensor intermittently dropping out. Smelling a rat - I checked the output voltage to the sensor at the module & confirmed that dropping out intermittently - one f##ked ABS module 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 4, 2015 You have to space the rear ABS sensors on the compact when you fit the E30 axles with the medium case diff. The outer Cv's are larger..... I've done this on mine & it all works fine. You may have damaged the sensor ring on the joint by fitting the sensors without a spacer Quote Share this post Link to post Share on other sites
Shunty 0 Report post Posted November 6, 2015 Scan it to see what fault comes up Can I scan it with OBD scanner? Quote Share this post Link to post Share on other sites
Shunty 0 Report post Posted November 6, 2015 You have to space the rear ABS sensors on the compact when you fit the E30 axles with the medium case diff. The outer Cv's are larger..... I've done this on mine & it all works fine. You may have damaged the sensor ring on the joint by fitting the sensors without a spacer I suspect I have damaged it... is the sensor ring removable? I still have old axles... could I swap ring? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 6, 2015 Ring size is different Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted November 27, 2015 Can I scan it with OBD scanner? Using INPA in ODB mode worked fine for me, told me that rear sensors were picking up pulse fails at 50km/h, turns out I didn't have any ABS rings on my 325i half shafts Quote Share this post Link to post Share on other sites
