Brook-e30 0 Report post Posted December 1, 2015 Good Condition LSD to suit E12 or E24Medium Case diff.As far as I'm aware, the ratio is 3.07 Is a non Speedo Type.$650 cash for Bimmersport members. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 1, 2015 (edited) I could be keen. Just investigating if it will fit my e28 EDIT: looks like a no go http://www.mye28.com/viewtopic.php?t=44635 Edited December 1, 2015 by eliongater Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted December 1, 2015 What is that can on the side? Some kinda breather / oil reservoir? Quote Share this post Link to post Share on other sites
BM WORLD 1288 Report post Posted December 2, 2015 I could be keen. Just investigating if it will fit my e28 EDIT: looks like a no go http://www.mye28.com/viewtopic.php?t=44635 no Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 2, 2015 Med case like any other med case? Can be fitted to other housings like e30/e36? If so could be keen to swap for 3.64 e30 lsd? Quote Share this post Link to post Share on other sites
Brook-e30 0 Report post Posted December 2, 2015 No it wont fit E30/E36. It is a lot different from them, and also has no speedo reading like E30's do. As far as I'm aware it only fits E12 and E24. Cheers Quote Share this post Link to post Share on other sites
will 169 Report post Posted December 2, 2015 Tony is referring to the internals being the same as those found in an e30 med case LSD so he can swap them into an e30 casing for his v8. The 3.64 he has does not allow for the crownwheel/pinion to be swapped for a 3.07 as the crownwheel mounting on the 3.64 LSD unit has a different offset to the 3.07 unit. IIRC it is not the same..? Been a VERY long time since I had one of these open though.. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 5, 2015 Thanks wil. Doubt he'll let me pull it to bits to measure ha. Quote Share this post Link to post Share on other sites
