mal6 0 Report post Posted December 15, 2015 HELP Had new battery fitted & need the stereo s code , so pulled stereo & been in touch wiht BMW but the numbers on the label or bar code numbers or even Philips numbers dont match anything they can find . Is there other numbers somewhere that will correspond . I prefer to keep the car origonal ratrher than buy new unit Quote Share this post Link to post Share on other sites
M3AN 4110 Report post Posted December 16, 2015 If it's original they can trace it back from the VIN I believe. But they should have been able to tell you that??? Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 16, 2015 ring pacific wholesalers . it might be this company name now , been a while since I have called them . http://www.panpacific.net.nz/Public/Contact Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 16, 2015 ring pacific wholesalers . it might be this company name now , been a while since I have called them . http://www.panpacific.net.nz/Public/Contact Pans wont be able to help with a code. They are parts wholesalers Quote Share this post Link to post Share on other sites
allan 295 Report post Posted December 16, 2015 Have you tried here https://www.radio-code.co.uk/philips-radio-codes.html. It appears that some units are coded to the cars vin number in the factory and can only be decoded by a main dealer if your lucky. While others are just coded and the code can be obtained by using a site like the one above. To do this it appears you could need the following info vin number off the car, radio make, model, serial number, bar code if present. It's a real pain in the arse and everybody want $$$$ off you to do it if you are unable to do it yourself it soon adds up. best of luck Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted December 17, 2015 (edited) Have heard of you take The top cover off the code is printed either on the circuit board or somewhere under it Or try this https://www.radio-code.co.uk/bmw-radio-codes.html Edited December 17, 2015 by euroriffic Quote Share this post Link to post Share on other sites
