M M 250 Report post Posted December 26, 2015 Did the e36 upgrade so no longer need these. All worked before being removed. 2 have the arrows worn off. 4 available, $7 each or $20 for the lot. Will have another 2 when I do the back door switches as well. $30 if you want all 6. Quote Share this post Link to post Share on other sites
scottbeattie 63 Report post Posted December 26, 2015 What's the benefit of the E36 switches? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
nick496 271 Report post Posted December 26, 2015 Just nicer to press, as they use a rocker. Quote Share this post Link to post Share on other sites
scottbeattie 63 Report post Posted December 26, 2015 Cool, might look into doing the same then Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
M M 250 Report post Posted December 27, 2015 (edited) That and they are illuminated. Much nicer overall. Can post a picture if you like. Edited December 27, 2015 by M M Quote Share this post Link to post Share on other sites
scottbeattie 63 Report post Posted December 27, 2015 That and they are illuminated. Much nicer overall. Can post a picture if you like.Yep I'd like to see a picSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
M M 250 Report post Posted December 27, 2015 2 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 27, 2015 e28 models also came in illuminated switches probably only in 535i etc. simple swap out though . e36 switches are nicer to use though , but they do burn out more often Quote Share this post Link to post Share on other sites
M M 250 Report post Posted December 27, 2015 e28 models also came in illuminated switches probably only in 535i etc. simple swap out though . e36 switches are nicer to use though , but they do burn out more often I thought I saw some illuminated versions of the original ones online before but wasn't sure. Not hard to find more E36 switches if they do go. Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 27, 2015 I thought I saw some illuminated versions of the original ones online before but wasn't sure. Not hard to find more E36 switches if they do go. only the early e36 models use those high current switches and the stocks are starting to dry up as the contacts do burn out. all the later e36 models use soft contacts and relay boxes etc Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted December 28, 2015 e28 models also came in illuminated switches probably only in 535i etc. simple swap out though . e36 switches are nicer to use though , but they do burn out more often The 525ee got the illuminated ones Quote Share this post Link to post Share on other sites
M M 250 Report post Posted December 28, 2015 only the early e36 models use those high current switches and the stocks are starting to dry up as the contacts do burn out. all the later e36 models use soft contacts and relay boxes etc Oh I see. I take it the newer ones are the small plug ones then? Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 28, 2015 Oh I see. I take it the newer ones are the small plug ones then?yes Quote Share this post Link to post Share on other sites
