Joel61 9 Report post Posted January 25, 2016 Hey everyone So every so often my yellow/orange oil light comes on, then when I turn my car off its still on. Once I turn it back on again it goes away and and doesn't come back for a while. I checked the oil and it seems to be full. Does this mean I have an intermittent sensor? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 25, 2016 Common fault- thermal level sensor in sump Quote Share this post Link to post Share on other sites
Joel61 9 Report post Posted January 25, 2016 Common fault- thermal level sensor in sump Do you know how much they normally are and where I could get one from? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 25, 2016 (edited) I would only go new . I can supply for $236.26 + Gst Edited January 25, 2016 by *Glenn* Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted January 26, 2016 Hey Joel, replace the sensor rubber o-ring gasket at the same time - its only about $10 1 Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted January 26, 2016 Interesting, I have the same issue. What are the side affects to not fixing this? I presume just you don't know when your oil is low? 1 Quote Share this post Link to post Share on other sites
Joel61 9 Report post Posted January 26, 2016 Interesting, I have the same issue. What are the side affects to not fixing this? I presume just you don't know when your oil is low?At the moment I haven't had any side effects(had going for about 4 months) , but the others might say otherwise Quote Share this post Link to post Share on other sites
