Autoglym 255 Report post Posted July 7, 2016 Hi guys, I have an E36 328 Coupe & have had this happen a few times now, so after filling up, the gauge stays on empty, when the vehicle is started & stays like it!! I did a little bit of research & found that it is caused by having the ignition key on when filling up, the other forum I found it on, recommends to remove the key when filling up & the remedy is to remove fuses 31 & 46 with the key removed So I did this yesterday & has fixed the gauge fault, I thought it was the fuel sender, but no!! So google is your friend, I even priced up another sender Have any of you guys encountered this?? Barry Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted July 7, 2016 The fuel gauge on our 318i regularly says empty when we start up in the morning. Flicking the fascia above the needle sorts it. It's called character. Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted July 8, 2016 Flicking the fascia above the needle sorts it. It's called character. Lol that's called a needle that's bent/warped over time and heat.... it'll be catching on something. Common problem with a lot of cars. Changing the needle will fix that. Quote Share this post Link to post Share on other sites
Neal 568 Report post Posted July 8, 2016 wives 328i had two issues which also gave empty fuel light on issues. 1, wire had broken off from fuel sensor (soldered back on with the usual precautions take when working around fuel tanks) 2. A section of wire under rear seat had become damaged and needed replacement ( not obvious to the eye) Quote Share this post Link to post Share on other sites
