Mr Hyde 44 Report post Posted August 8, 2016 1 hour ago, jin108 said: Yeah agree 400hp makes the car unmanageable and twitchy and before you know it you are spending more money on suspension upgrades. Its a good car but the power overwhelms the chassis so harder bushings and shocks/dampers are needed to make it handle better. Unless you are a point and shoot kind of guy then yeah go full bolt on and up the boost to 20psi. Agree 400 hp is mental and putting all the power to the ground is difficult. I keep getting wheel spin. An LSD might be worth the investment. It is nice to have that much power for overtaking but isn't always necessary. 1 Quote Share this post Link to post Share on other sites
Stevie S 49 Report post Posted August 8, 2016 decent tires and lsd make a big difference. Putting a wavetrac in was one of my best investments Tuning tools like MHD, cOBB AND jB4 have software rattle reduction options. I use mhd but choose not to use the rattle fix as it can increase lag a pinch Quote Share this post Link to post Share on other sites
jin108 25 Report post Posted August 8, 2016 Pretty sure the software fixes just change default WG position more open so it wont rattle. It then takes longer to close when building boost so increases lag. Quote Share this post Link to post Share on other sites
Mr Hyde 44 Report post Posted August 8, 2016 6 hours ago, mattone74 said: decent tires and lsd make a big difference. Putting a wavetrac in was one of my best investments Tuning tools like MHD, cOBB AND jB4 have software rattle reduction options. I use mhd but choose not to use the rattle fix as it can increase lag a pinch Steve, what did your wavetrac + install cost? I would love to get one as the tires I have on are premium but still not enough to get all the power down. Quote Share this post Link to post Share on other sites
Stevie S 49 Report post Posted August 8, 2016 It was a while ago but about $1300 for the diff and about 500-600 for install. Also depends on wether your factory diff is bolted or welded. They varied depending on build date, welded is a lot harder. Mine was bolted Quote Share this post Link to post Share on other sites
Mr Hyde 44 Report post Posted August 8, 2016 1 hour ago, mattone74 said: It was a while ago but about $1300 for the diff and about 500-600 for install. Also depends on wether your factory diff is bolted or welded. They varied depending on build date, welded is a lot harder. Mine was bolted Thanks, pretty reasonable then. Cool looking wagon you've got there! Now to see what kind of diff I have.... Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted August 9, 2016 400 hp too much? I guess we are on a different page on that one, but I do agree that that an LSD is a very wise option. Quote Share this post Link to post Share on other sites
HELLBM 1671 Report post Posted August 9, 2016 Retrofitted an E9x M3 LSD and 1/2 shafts into my E90 335 to make sure that the rear can handle whatever is thrown at it. Highly recommended conversion. 3 Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted August 12, 2016 Due to building a house im looking at selling mine unfortunately. 2007 MS done 75K from JPN Mint condition inside and out, coded extras, running JB4, paddle shift, plugs, cabin filters, oil/filter just done. $26K. PM me if interested. 2 Quote Share this post Link to post Share on other sites
fatjoez 3 Report post Posted August 14, 2016 2007 335i with MHD ecu tune Stage 1 here. Stock charge pipe no issues yet but will probably upgrade the charge pipe. MHD ecu tune stage 1 is rated around 340HP, same as 1M. 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted August 14, 2016 Yes have to agree with Ron here, In the 80's I had 400HP albeit in a chassis with far far less capability to what we have now. Having looked at the wastegate issue when I buy a 335i I will likely just pull the turbos off and rebuild the wastegates myself with a rebuild kit, whole process is quite straightforward. That way I will have at least 50,000 KMs (probably more) without having to worry about boost leakage. I have factored into my purchase price and walnut clean of the cylinder head, a few bolt on parts (Charge pipe especially) a wastegate rebuild and a transmission service. This will add a couple of grand but will give me peace of mind that the car will be what I expect from the get go. The rattle as I now see it is one problem but the wear in the bushing is the real issue and it would seem that the two issues are often discussed as one thing and while connected they are two different issues. 2 Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted August 15, 2016 By the car, put a mechanical warranty on it and enjoy it. Speaking from experience, If you worry about all the issues you could possibly be faced with you'll never go near one but I guess that's the case with all high performance BMW's..... 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted August 15, 2016 Fair to say if you are worried about mechanical issues then perhaps a BMW should no be your first choice. That said the 335i offers tremendous bang for your buck as a driver's car. For me I like to know the issues that plague any car as that has a direct relationship to the aforementioned bang for buck ratio. Plus I just like mechanical things to be right. Quote Share this post Link to post Share on other sites
Olaf 3411 Report post Posted August 15, 2016 4 hours ago, Herbmiester said: Fair to say if you are worried about mechanical issues then perhaps a BMW should no be your first choice. That said the 335i offers tremendous bang for your buck as a driver's car. For me I like to know the issues that plague any car as that has a direct relationship to the aforementioned bang for buck ratio. Plus I just like mechanical things to be right. 3 hours ago, 3pedals said: Same, tend to do homework, buy well and maintain well - been a successful approach to owning cars that others would consider high rent. Regardless of what the item is, be it: bicycles, cars, hifi or motorbikes , the whinge brigade is active on forums and social media creating a cloud of mis-information not worth the electrons it taxes to exist. Homework + remedials = fun times. yep, we're of the same mind. I too do my research before acquisition. Make an informed decision, plan for the fixes. I'd rather do it up front and get the use, than do it at the back end and pass on the benefits to the next owner, at my cost! Quote Share this post Link to post Share on other sites
