BreakMyWindow 1984 Report post Posted August 26, 2016 (edited) Frisbee/Automotive art. Free. E39 Board monitor. Comes with rare Titan line trim surrounding. Good working condition, all buttons work. $100 2x E39 CD stackers. Both work but skipped over bumps. $15 ea Used E39 M5 clutch disc and pressure plate. Still some life left, or use to rebuild? SOLD. Used E39 M5 dual-mass fly wheel.Some radial play, not sure what is acceptable. No axial play though. SOLD. Parts are all in Auckland. Edited October 26, 2016 by BreakMyWindow Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted August 27, 2016 Is the pressure plate a self adjusting unit? Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted August 27, 2016 Yep Quote Share this post Link to post Share on other sites
MrDevine 14 Report post Posted August 29, 2016 Will the board monitor work OK in my E39 2003 540i? Could be keen on the CD stacker too. Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted August 29, 2016 45 minutes ago, MrDevine said: Will the board monitor work OK in my E39 2003 540i? Could be keen on the CD stacker too. Depends if your car was originally spec'd with the board monitor option. If it was then ideally you'd want a 16:9 wide screen monitor but this would still work. Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted August 30, 2016 2x E39 Sport seat lower plastic seat covers. The ones that usually break. Passenger side is brand-new, Drivers side has one piece that is broken off, but can be easily glued back on and it will be secured like new. Black in colour. $70 the lot or $30 each. Identical to these : Quote Share this post Link to post Share on other sites
M3AN 4162 Report post Posted August 30, 2016 1 hour ago, BreakMyWindow said: Black in colour. $70 the lot or $30 each. Good bulk discount that! Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 30, 2016 Fwiw, the OEM fan on the wifes E39 530i with similar damage grenaded itself on the way home from Ohakune about a month ago. Might pay to bin it before someone else has a similar ballache Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted August 30, 2016 10 hours ago, Ahmedsinc said: Fwiw, the OEM fan on the wifes E39 530i with similar damage grenaded itself on the way home from Ohakune about a month ago. Might pay to bin it before someone else has a similar ballache Sure that wasn't attributed to the viscous coupling seizing in a locked state? Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted August 31, 2016 12 hours ago, BreakMyWindow said: Sure that wasn't attributed to the viscous coupling seizing in a locked state? New OEM coupling fitted along with full coolant hose refresh 6 weeks before I went on holiday. Original fan had a couple of tiny chips missing from the leading edge of 2 vanes, didn't think it would be a problem as the plastic wasn't outwardly showing any sign of degradation. Had a good look at the remnants of the hub after the fact & the plastic was browned out in the middle but still nice and black at the surface. Still unsure how I avoided taking any coolant hoses / sensor wiring out when it let go! Quote Share this post Link to post Share on other sites
M3AN 4162 Report post Posted August 31, 2016 Not to mention a good dent in the hood. Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted September 1, 2016 15 hours ago, Ahmedsinc said: New OEM coupling fitted along with full coolant hose refresh 6 weeks before I went on holiday. Original fan had a couple of tiny chips missing from the leading edge of 2 vanes, didn't think it would be a problem as the plastic wasn't outwardly showing any sign of degradation. Had a good look at the remnants of the hub after the fact & the plastic was browned out in the middle but still nice and black at the surface. Still unsure how I avoided taking any coolant hoses / sensor wiring out when it let go! Fair enough hairy muff. Have edited the original post. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted October 20, 2016 up Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted October 21, 2016 martin ,clutch kit still for sale ? Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted October 21, 2016 1 hour ago, jeff002 said: martin ,clutch kit still for sale ? Yep. Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted October 21, 2016 45 minutes ago, BreakMyWindow said: Yep. martin ,i will take the clutch kit and flywheel.pmd Quote Share this post Link to post Share on other sites
Dogballs 123 Report post Posted October 23, 2016 Are the video modules still avaliable? Pm me if they are... thanks Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted October 26, 2016 Clutch and flywheel sold. Quote Share this post Link to post Share on other sites
