User Name 19 Report post Posted August 31, 2016 Hi All, I know this has been discussed before awhile back but i have hit a road block with my turbo manifold and wanted peoples opinion before i go and start spending $$$ So i managed to semi build myself an turbo manifold with individual runners but have run into issues on the collector end as i don't really have space for the wastegate unless i mount it on top of collector (which with my welder blowing a gas bottle, i need a new regulator + gas so that's about 350-400 i can put on that or someone else finishing my exhuast off) So check out pics attached and let me know your thoughts (Note i have a twin scroll turbo) 1. Go back to log style manifold (more space but likely wont support my power numbers i want) 2. Keep as is with bottom mount and have someone finish off the manifold 3. Keep same style but change to top mount (only issue is getting 2.5" outlet into two pipes, which i confirmed will just fit between last runner & firewall and 6/5) 4. Buy this and just get a 50mm flange installed - http://www.ebay.com/itm/BMW-M30-T4-Turbo-Manifold-E30-E32-E34-E28-E24-E23-E9-/131806544376 5. Or go with this guys idea (pictures at top and bottom of page) and make down pipes fit - http://www.r3vlimited.com/board/showthread.php?t=285809 I am personally leaning towards options 3/4/5 but i do like option 5 as i could probably do with materials i currently have and just tac together and get someone to finish off but noticed there is no wastegate (so don't know if space is there) So let me know what you think and if need be we will do a poll and go for it + anyone know any good fabricators in manwatu/welly region as i would prefer local rather than sending the car somewhere else in the country. Note: Topcat , BMWorld and other members have been awesome so far with info and i will be representing bimmersport once this is up and running (dreams) 2 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted September 1, 2016 Log manifold Are you tacking with a gasless mig? If you want I can point you in the right direction in terms of welder setup. Where are you getting gas from? Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted November 10, 2016 Quick Update: Manifold has been completely re-designed due to changing turbo setup - Now be running Holset HX40R split pulse T3(when it arrives), Two Manifolds are being built with equal length runners x2 40mm wastegates - Just waiting on parts to arrive before getting it mocked up and Tig welded together by a local guy who has helped out big time and convincing some of the local guys to work on for me that wanted nothing to do with it. - Then will be going for HPC Coating along with some other engine parts - Will post pics hopefully next week as we get it mocked up Fuel system parts arrived - Just need to purchase injectors and some more braided hose. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted November 13, 2016 HX40R ? Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted November 15, 2016 I have no idea where my spec sheet went with the details and exact part number 63mm/67mm .85 A/R (Sounds about right) Think HX40 with a bit of magic added from Steve Merc. I believe the ATJ Drijt (D1 NZ) boys are running them in there cars and at the moment using hx35 for mock up Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted November 15, 2016 That would be me then, they run a Pro35 on the RB30 and HRC40rs 66mm billet in the 2J Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted May 29, 2019 Hi All, Long time since an update, but after some health issues that have stopped my life for last few years. Finally getting back on track with the car, Updated V5 or something of the manifold is a few weeks away from being all welded up. Once its back it home i will need to run the pipes down from the twin wastegates and finishing plumbing up the exhaust (downpipe for turbo already done)/ intercooler. Then re-pump fuel system for new surge tank .... and then the engine crusade will begin (glad things have got cheaper and more available in last few years)... Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted June 13, 2019 Shame I didn't see this a while ago. Moved to the US and could have sold you or lent you my manifold I had made in Sweden. It's a proven one they use on there 900hp M30 E34. It doesn't have the wastegate on it as they left that up to me to place it once I figure out how much space I need. Nice work though. Sometimes its about the effort rather than just buying one like I did. Quote Share this post Link to post Share on other sites
Karun 23 Report post Posted July 19, 2021 Hey Driftit any chance you still have that manifold? 😅 would love to pick your brain about turbo m30s at some point. Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 23, 2021 To think years on i still haven't finished this project, amazing how life can get in the way. Also had to modify the manifold a few times due to fitment issues but since were in lockdown sorting out the downpipes and test fitting the engine, so i can do lots of small things before doing internals that no-one sees I do admit the thing about time makes you change so many things and also allows access and time for parts to come down in price, everything was custom originally and now at least there is more of a market. The big pain for me now is my custom turbo just feels to small for goal but have to start somewhere. Eventually my V12 will end up with something but that's for a time when im rich. Stay safe all Quote Share this post Link to post Share on other sites
