User Name 19 Report post Posted November 14, 2016 Hi Team, I know this has been discussed in another thread by me but as time has progressed and turbo setup has changed i had to make some extra space and wanted to see if people think this will pass or if i am better just making a new one Orginal: e28 Mount attached to block via 6mm plate (wasn't space friendly) Current: M5 Mount + 10MM Steel Plate attached to e32 block ( i have put threads in the plate so it threads all way through) Or Do i use the spare 10mm steel i have and just create one (welded or just heat up plate and bend then tread) basically be reserve of M5 mount Quote Share this post Link to post Share on other sites
gjm 3289 Report post Posted November 14, 2016 I'd be using a single mount from block to chassis/frame/body, rather than a mount, and a piece of plate. It may require something to be fabricated, but the strength and construction are then easy to prove. Is there any precedence for a two-piece engine mount? That's most likely the guideline. Quote Share this post Link to post Share on other sites
KwS 2442 Report post Posted December 5, 2016 This is one of those instances where you would be best talking to your certifier about it, and see what solution they would prefer. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted January 3, 2017 From my experience this would be totally fine. Just make sure you use bolts 8.8 or 10.9 (better) and locking washers. 10mm is ideal. 6mm is the min for engine brackets. 1 Quote Share this post Link to post Share on other sites
