Karter16 416 Report post Posted December 8 Today I cleaned up the top front RACP points and sprayed with the e-coat matched enamel I have. First up I masked the area around the mount (photo taken prior to clean up). Then I used a ziploc bag as a miniature spray booth by taping it to both the RACP and the spray can. I also made sure to cover/block every other hole/exit point in the RACP so I didn't get any over spray wafting out anywhere. This approach worked really well, the whole thing only took about 15 minutes to do. And the end result (paint is still wet here): I have some clean up to do on a few rust spots on the seat bench, but will do this once I have the A08 in hand and can touch it up properly. At this point though the front mounts are ready for the installation of the brace (drilling and tapping will be done at the time of installation of the brace as I need to take the subframe off to tap the threads. 2 Quote Share this post Link to post Share on other sites
Karter16 416 Report post Posted December 12 I've been going through the public XDF for the 0401 binary and sorting out some of the incorrect references. They're usually pretty easy to confirm by looking at whether the data makes sense. This one made me chuckle 😛 1 Quote Share this post Link to post Share on other sites
Karter16 416 Report post Posted December 14 (edited) I've spun up a thread (https://nam3forum.com/forums/forum/special-interests/coding-tuning/287069-csl-0401-program-binary-disassembly-notes) in the Coding section which I will keep updated as I work through the disassembly. Aim is to make the info easy to find and also splits it out from this build thread. Edited December 14 by Karter16 Quote Share this post Link to post Share on other sites
Karter16 416 Report post Posted Saturday at 04:00 AM Finally made it to my summer break! Did a quick fitment check of the airbox, filter and Haimus snorkel to make sure I don't get any surprises during install. I've noted others have found the hose attachments to be tight so am prepared that I might need to do some adjustments there like heinzboehmer did to get them to click in correctly. The CSL dipstick tube is finally with the local courier for delivery, more than 6 months after I ordered it, so should get it in the next few days. The only other thing I'm waiting on is the silver replacement screws for the two halves of the airbox, but they aren't a blocker given I can use the ones the airbox came with and swap out easily later. 1 Quote Share this post Link to post Share on other sites
Karter16 416 Report post Posted 20 hours ago (edited) Yesterday afternoon I conditioned the intake boots and clamped them to the airbox. The tool for the Oetiker clamps works out at about $100NZD however you approach it so I saved $85 dollars by using the dremel to modify some standard $15 SuperCheapAuto clamp pliers. This worked very nicely - I'll paint the pliers so they don't rust and they can go in the toolbox for next time. I also installed 2x new rubber isolators - Being 20 years old the rubber in the current ones is probably soft and perishing. Plans for between now and whenever the dipstick tube turns up is to remove the LHS radiator cowl shield in preparation for installing the airbox. Yesterday I also took the car for a drive and logged the relevant variables with TestO to get a baseline capture before I go making any changes to the car. I want to make sure I'm as prepared as I can be for moving across to the 0401 program. To that end I will also be doing another full review of each change I've made to the partial as part of v1 of my tune. It's been long enough now since I did it that I should be able to do a good review of it and make sure I haven't made any mistakes. Edited 20 hours ago by Karter16 2 Quote Share this post Link to post Share on other sites
Cement 891 Report post Posted 18 hours ago That's some pretty pornographic carbon work for sure 🍆 I like the paint booth, about to do something similar in my kitchen 🤣 Gotta love those holiday projects hah Quote Share this post Link to post Share on other sites
