My545
Rough Running E60
My 04 545i is now running real rough. Started with just the odd what sounded like a miss fire when cold a couple a weeks ago and would soon come right and idle smoothly. Now it's constantly running rough, not 100% if it's a misfire, or running on 7 or what. I have tried cleaning the mass airflow sensor as one thing I might be able to do but made no difference.
Any thoughts or suggestions greatly appreciated. I'm in Dunedin, if anyone here would be willing to help, yarn or suggest someone who may be able to help that would be great. I have just bought a K+DCAN cable to have a crack at trying to work out what might be wrong, but need to work out how to use that first too.
Cheers Sam
So Installed some software and plugged laptop into car with trepidation and got the following codes, screen shots etc. Any help deciphering this would be great.
Maybe O2 sensors and a miss fire on 6 and 8. New coils maybe??
          E R R O R   M E M O R Y           --------------------------------------Date:      10.03.2017 21:41:22 ECU:       ME9N62 JobStatus: OKAY Variant:   ME9N62 ------------------------------------------------------------RESULT:    7 error in error memory ! ------------------------------------------------------------27A0  CDKELS - Ansteuerung E-Box Luefter Error counter:    4 Logistic counter: 40 1. Umweltsatz   Mileage                                 135944     km   Motordrehzahl (nmot)                       720.00  /min   Motortemperatur (tmot)                      46.50  Grad C   Versorgungsspannung (ub)                    14.13  V   Fahrzeuggeschwindigkeit (vfzg_u)             0.00  km/h 2. Umweltsatz   Mileage                                 135944     km   Motordrehzahl (nmot)                       880.00  /min   Motortemperatur (tmot)                      22.50  Grad C   Versorgungsspannung (ub)                    13.00  V   Fahrzeuggeschwindigkeit (vfzg_u)             0.00  km/h 3. Umweltsatz   Mileage                                 137512     km   Motordrehzahl (nmot)                       760.00  /min   Motortemperatur (tmot)                      17.25  Grad C   Versorgungsspannung (ub)                    13.66  V   Fahrzeuggeschwindigkeit (vfzg_u)             3.00  km/h   kein Signal oder Wert   Testbedingungen erfüllt   Fehler momentan vorhanden und bereits gespeichert   Fehler würde kein Aufleuchten einer Warnlampe verursachen   Diagnose aktiv Error code: 27 A0 64 01 00 00 04 28 42 61 12 7E 96 00 42 61            16 5E 8A 00 43 25 13 57 91 03 ------------------------------------------------------------27DA  CDKDGEN - Generatorfehler Error counter:    3 Logistic counter: 15 1. Umweltsatz   Mileage                                 136664     km   Versorgungsspannung (ub)                    13.28  V   Generatorspannung (ugen)                    15.00  V   Motordrehzahl (nmot)                      1560.00  /min   vom Generator empf. Lastsignal (dffgen)     37.65  % 2. Umweltsatz   Mileage                                 136784     km   Versorgungsspannung (ub)                    12.91  V   Generatorspannung (ugen)                    14.80  V   Motordrehzahl (nmot)                       840.00  /min   vom Generator empf. Lastsignal (dffgen)     53.33  % 3. Umweltsatz
   Mileage                                 137016     km   Versorgungsspannung (ub)                    13.38  V   Generatorspannung (ugen)                    15.00  V   Motordrehzahl (nmot)                       720.00  /min   vom Generator empf. Lastsignal (dffgen)     47.06  %   Signal oder Wert oberhalb Schwelle   Testbedingungen erfüllt   Fehler momentan nicht vorhanden, aber bereits gespeichert   Fehler würde kein Aufleuchten einer Warnlampe verursachen   Diagnose aktiv    Fehler in Entprellphase Error code: 27 DA 21 21 00 00 03 0F 42 BB 8D 2C 27 60 42 CA            89 2A 15 88 42 E7 8E 2C 12 78 ------------------------------------------------------------274E  CDKMD - Aussetzererkennung, Summenfehler Error counter:    2 Logistic counter: 38 1. Umweltsatz   Mileage                                 137496     km   Motordrehzahl (nmot)                      3400.00  /min   relative Luftfuellung (rl)                  87.75  %   Motortemperatur (tmot)                      72.00  Grad C   Tankfuellstand (tfst)                       15.00  l 2. Umweltsatz   Mileage                                 137504     km   Motordrehzahl (nmot)                       920.00  /min   relative Luftfuellung (rl)                  30.75  %   Motortemperatur (tmot)                      11.25  Grad C   Tankfuellstand (tfst)                       14.00  l   Signal oder Wert oberhalb Schwelle   Testbedingungen erfüllt   Fehler momentan nicht vorhanden, aber bereits gespeichert   Fehler würde das Aufleuchten einer Warnlampe verursachen   Diagnose aktiv    Fehler in Entprellphase Error code: 27 4E A1 21 00 00 02 26 43 23 55 75 A0 0F 43 24            17 29 4F 0E FF FF FF FF FF FF ------------------------------------------------------------2745  CDKMD03 - Aussetzererkennung Zyl.8 P0308 Cylinder 8 Misfire Detected Error counter:    2 Logistic counter: 38 1. Umweltsatz   Mileage                                 137496     km   Motordrehzahl (nmot)                      3400.00  /min   relative Luftfuellung (rl)                  87.75  %   Motortemperatur (tmot)                      72.00  Grad C   Tankfuellstand (tfst)                       15.00  l 2. Umweltsatz   Mileage                                 137504     km   Motordrehzahl (nmot)                       920.00  /min   relative Luftfuellung (rl)                  30.75  %   Motortemperatur (tmot)                      11.25  Grad C   Tankfuellstand (tfst)                       14.00  l
   Signal oder Wert oberhalb Schwelle   Testbedingungen erfüllt   Fehler momentan nicht vorhanden, aber bereits gespeichert   Fehler würde das Aufleuchten einer Warnlampe verursachen   Diagnose aktiv    Fehler in Entprellphase Error code: 27 45 A1 21 03 08 02 26 43 23 55 75 A0 0F 43 24            17 29 4F 0E FF FF FF FF FF FF ------------------------------------------------------------299B  CDKDIBS1 - Kommunikation DME - IBS Error counter:    6 Logistic counter: 36 1. Umweltsatz   Mileage                                 137504     km   IBS-Fehler 1 (ibsderrs1)                    59.00  bin   IBS-Fehler 2 (ibsderrs2)                     0.00  bin   Motordrehzahl (nmot)                       880.00  /min   Versorgungsspannung (ub)                    13.66  V 2. Umweltsatz   Mileage                                 137504     km   IBS-Fehler 1 (ibsderrs1)                    59.00  bin   IBS-Fehler 2 (ibsderrs2)                     0.00  bin   Motordrehzahl (nmot)                       760.00  /min   Versorgungsspannung (ub)                    14.60  V 3. Umweltsatz   Mileage                                 137504     km   IBS-Fehler 1 (ibsderrs1)                    59.00  bin   IBS-Fehler 2 (ibsderrs2)                     0.00  bin   Motordrehzahl (nmot)                       560.00  /min   Versorgungsspannung (ub)                    14.13  V   Signal oder Wert oberhalb Schwelle   Testbedingungen erfüllt   Fehler momentan nicht vorhanden, aber bereits gespeichert   Fehler würde kein Aufleuchten einer Warnlampe verursachen   Diagnose aktiv    Zyklus-Flag gesetzt   Fehler in Entprellphase Error code: 29 9B 21 25 00 00 06 24 43 24 3B 00 16 91 43 24            3B 00 13 9B 43 24 3B 00 0E 96 ------------------------------------------------------------2783  CDKLM - Heissfilmluftmassenmesser Error counter:    1 Logistic counter: 38   Mileage                                 137512     km   Motordrehzahl (nmot)                       680.00  /min   Ansauglufttemperatur (tans)                -39.75  Grad C   Winkel DK bez. auf DK-Anschl. (wdkba)        4.31  % DK   ADC HFM (adhfm)                              0.00  V   Signal oder Wert unterhalb Schwelle   Testbedingungen erfüllt   Fehler bisher nicht aufgetreten   Fehler würde kein Aufleuchten einer Warnlampe verursachen   Diagnose aktiv Error code: 27 83 02 01 00 00 01 26 43 25 11 0B 0B 00 FF FF            FF FF FF FF FF FF FF FF FF FF
------------------------------------------------------------27B8  ???? FS_LESEN_DETAIL: JobStatus: ERROR_TABLE =============================================================
       E R R O R   M E M O R Y           ----------------------Date:      10.03.2017 21:19:18 Model:     E60 Scope:     all control module JobStatus: OKAY Quantity:  39 ----------------------------------------------------------------ADR Gen. name  JobStatus 1B  VVT        ERROR_ECU_SERVICE_NOT_SUPPORTED 1E  VVT2       ERROR_ECU_SERVICE_NOT_SUPPORTED ----------------------------------------------------------------  ADR Gen. name  JobStatus Number of errors              Error code   Kind of error  00  ZGM        OKAY      No Error stored  01  SIM/SGM    OKAY      3 Error stored                93C1         20                93CC         20                93CD         20  02  SZL        OKAY      No Error stored  05  STVL/TEFA  OKAY      No Error stored  06  STVR/TEBF  OKAY      No Error stored  0E  SFZ        OKAY      No Error stored  12  DME/DDE    OKAY      7 Error stored                27A0         64                27DA         21                274E        A 1                2745        A 1                299B         21                2783         02                27B8         28  16 A FS        OKAY      4 Error stored                6140         30                614A         30                CE93         30                CE99         38  18  EGS        OKAY      No Error stored  22  ????       OKAY      No Error stored  29  DSC        OKAY      1 Error stored                5F14         E0  36  TEL        OKAY      No Error stored  3C  CDC        OKAY      No Error stored  3F A SK        OKAY      No Error stored  40  CAS        OKAY      No Error stored  41  DWA        OKAY      No Error stored  43  POW        OKAY      No Error stored  44  SHD        OKAY      No Error stored  45  RLS        OKAY      No Error stored
  47 A NTTU      OKAY      No Error stored  4B  VIDEO      OKAY      No Error stored  50  SINE       OKAY      No Error stored  60  KOMBI      OKAY      No Error stored  62  MOSTGW     OKAY      2 Error stored                E18C         20                E18F         20  63  MMI/CCC    OKAY      No Error stored  64  PDC        OKAY      No Error stored  65  BZM/SZM    OKAY      No Error stored  67  EC         OKAY      No Error stored  6D  FAS        OKAY      No Error stored  6E  BFS        OKAY      No Error stored  70  LM         OKAY      No Error stored  72  KBM        OKAY      No Error stored  73  CID        OKAY      No Error stored  78  KLIMA      OKAY      1 Error stored                9C54         64  A0  ????       OKAY      No Error stored  A1  SBSL       OKAY      No Error stored  A2  SBSR       OKAY      No Error stored =================================================================
Edited by My545
  On 3/10/2017 at 10:32 AM, qube said:
new spark plugs and coils should do it
Cheers, all eight?
Open them up and check the condition. I would do all of them and know they are all good than fix a couple to have a few more fails a month later.
it's the gehberhrenschitver valvugolpen. it's gefingerpokened kaputzezechtenarbened.
Assume the position and open your wallet, buddy.
/serious mode on
Kyu's analysis seems reasonable place to start.  What's a set of coils for the N62 worth? Oh, under USD200 for the new Bosch design, seems reasonable.
Definitely no vacuum leaks?  And your battery is strong and tests well yeah?
cheers
Cheers, SuperCheap auto have coils and plugs for $1250, anywhere do it better than that, seems pretty high or am I just really naïve, ignorant and cheap? probably all three.
I'm no mechanic or fool, but with a few YouTube vids are they easy enough to replace yourself?
/serious mode on
cheers
Haha cheers, getting cold feet about this Beemer thing already!!! $1250 for plugs and coils at Super Cheap, $200 USD sounds better, what site please?
/serious mode on
cheers
Not sure on vacuum leaks, had a good look around engine but don't really know what I'm looking for, assume battery OK.
yeah Supercheap and Repco are good for oil, car care, and running your Holden or Falcon.  For your Euro, you'll need a specialist supplier.
First stop should be the forum's supporters/sponsors.  As you're in Dunedin, you should try Milland.  http://www.milland.co.nz - and they're right there in Dunedin!  Euro Itallian are also said to be very good.
I've often used www.fcpeuro.com - started buying parts from them 12 years ago soon after buying my Volvo.
Seriously though, give Milland a call.  You may find they have what you need at good prices.
Hope that helps.
Hope that helps.
Yea cheers, ashamed to say I forgot about them and they're maybe six blocks away, although only on line. Used them a few years ago with E39. Thanks for reminding me.
fcp euro is cheap and quick (1 week delivery) and you have a range of different OEM or genuine to choose from at varying price points.
Spark plugs i paid about $50nzd for a set of 6 ngk branded ones whereas locally they were about $35 each.
Thanks for your help Kyu
K&G McCloud up Waverly is the place to go with euro stuff. Bmw send a lot of stuff up to them. They'll be able to diagnose the issue without throwing money at guesses to what it could be. Did it come with much of a service history?
Cheers, I just dropped it to my local garage on Hillside Road, will see what they say on Monday. Will keep K&G McCloud in mind definitely. Has service stamps from new, no information just that it's been done, have thought about trying to get history from previous garages up in Christchurch.
Something you will learn quickly with a BMW, is that unless its a basic oil change, taking it to your "local" isnt always a good idea. A good independent BMW specialist is the way to go. It may cost more in the hourly rate, but itll make up for it with a more accurate diagnosis and knowledge.
  • Like 3
