Kobra 180 Report post Posted March 28, 2017 (edited) Hi Guys, After reading many reviews, I acquired a set of BC gold (BR type) coilovers for my E30. I know the front struts need to cut off around 50mm above the spindle, then the new coilovers sleeve over the remaining 50mm, and are then welded to the spindle. I did some reading up on the LVV Cert rules for this modification (http://www.lvvta.org.nz/documents/standards/LVVTA_STD_Suspension_Systems.pdf, section 2.2(28)) It appears a change was made in August 2016 which states: Quote A non-adjustable strut modified by removing most of the strut tube down to the stub axle and sliding over a replacement threaded strut tube for the attachment of an adjustable spring platform, must: (a) not incorporate any modification of, or welding to, any cast or forged component, in particular the stub axle assembly; and ... Obviously this has me quite worried as I believe welding to the cast spindle is required. I thought welding to cast components can be done safely as long as the cast component is heated up to prevent cracking. Does anyone have an extra info or experience with this certification process? Edited March 28, 2017 by Kobra a word Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted March 28, 2017 I've got to ask - why not buy something designed for the E30 in the first place? If you got these for $5 and can do the work yourself then there's an economic argument, but that's about it. I don't like Scarles and don't rate them, but as has been said on another thread, they'll do coilovers - new - for about $1k. Quote Share this post Link to post Share on other sites
Kobra 180 Report post Posted March 28, 2017 17 minutes ago, gjm said: I've got to ask - why not buy something designed for the E30 in the first place? If you got these for $5 and can do the work yourself then there's an economic argument, but that's about it. I don't like Scarles and don't rate them, but as has been said on another thread, they'll do coilovers - new - for about $1k. These BC Gold coilovers are designed specifically for the E30, and bought them brand new from NZ Performance for $1.5k. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted March 28, 2017 That is the reason you cut the tube above the hub - The lower strut / hub is cast, the strut tube is steel so can be welded. Almost all E30 coilovers are done like this. 1 Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted March 28, 2017 (edited) Yeah weld to the strut tube. Doesn't hurt to find a certifier you want to use and talk to him about what your doing too Edited March 28, 2017 by musccoo 2 Quote Share this post Link to post Share on other sites
gjm 3299 Report post Posted March 28, 2017 22 minutes ago, Kobra said: These BC Gold coilovers are designed specifically for the E30, and bought them brand new from NZ Performance for $1.5k. 1 minute ago, e30ftw said: That is the reason you cut the tube above the hub - The lower strut / hub is cast, the strut tube is steel so can be welded. Almost all E30 coilovers are done like this. My apologies - my lack of E30-specific coilover, or BC, knowledge. I've used coilovers before on other cars, but it's been a case of unbolt various bits, and bolt up again. I didn't realise that with an E30 it's necessary to cut the original struts and weld to the new parts: I doubt it's something that's unique to the E30, but I've not heard of it before. (DIY coilovers is another matter!) While in the UK I worked on a tarmac rally E30 which had AST suspension. I don't recall any welding having been done to fit the front kit, but wasn't looking for it. That car had more than it's share of beautifully machined custom parts, too. From the sound of things you know what you're doing. I found this link which may be useful? Quote Share this post Link to post Share on other sites
Kobra 180 Report post Posted March 28, 2017 Great! This is the exact info I was looking for. I've been trying to track down a certifier in Christchurch, but the 2 I've called appear to be away on leave at the moment. Thanks guys Quote Share this post Link to post Share on other sites
