mal6 0 Report post Posted April 12, 2017 Where to get new clutch disc for my E36 328 coupe . The stuffed dual mass flywheel is being swapped over for a conventional l i have just got C/W pressure plate . BNT say only have the disc for dual mass type which is different doesnt have the anti vibration srings in it yet wksp manual says this model had either type . Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted April 12, 2017 na all 328i had dual mass . you will need to find out what flywheel you have ? whats it from ? WHAT SIZE DIAMETER DISC ETC , PICS WILL HELP CALL ME IF YOU WANT MORE INFO , MAY HAVE OPTIONS Quote Share this post Link to post Share on other sites
mal6 0 Report post Posted April 14, 2017 ^^^ Turns out its an after market clutch for M43/M44 engine Sachs product supplied by Clutch Systems flywheel &pp currently at the engine reconditioners getting refaced , no numbers on the disc cheers Quote Share this post Link to post Share on other sites
Blackie 510 Report post Posted April 14, 2017 Trademe. Lots of options including complete kits or individual disc. Quote Share this post Link to post Share on other sites
mal6 0 Report post Posted April 18, 2017 ^^^ Turns out its an after market clutch for M43/M44 engine Sachs product supplied by Clutch Systems flywheel &pp currently at the engine reconditioners getting refaced , no numbers on the disc cheer sJust to add the old disc is 215 mm diameter & inner flywheel srface is 220 mm diameter is this standard size for E40 E43 engines , dont want to geT wrong plate & be stuck with it . cheers (new price for dual mass f wheel& clutch is over $40000 !!!!) Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted April 18, 2017 call me Quote Share this post Link to post Share on other sites
mal6 0 Report post Posted May 9, 2017 Well the box is out & its got a lovely clean solid mass flywheel disc is worn cover is ok . Its done just on 200 k & NZ new so it would be origonal . So the mech is going to locate a clutch plate or get it remade . Guess I should have waited for the box to come out before buying solid conversion kit . So much forl 328s ALL having dual mass f wheel . Quote Share this post Link to post Share on other sites
Statek 87 Report post Posted May 9, 2017 Hey Malcolm. Got any info on the solid conversion kit you bought? I may be interested if it suits.. Quote Share this post Link to post Share on other sites
mal6 0 Report post Posted May 18, 2017 Well bit of a mission turns out my 328Is has a nice lightweight solid flywheel mech thinks its origonal . The E30 f wheel & clutch press plate & new clutch disc bolt up BUt its smaller & ring gear teeth dont mesh with the starter . So went to Auto Brake & clutch & bought new kit but its for dual mass f wheel so had to get another separate plate as well . replaced release bearing too .& skimmed the f wheel On road now. But the clutch is all at the bottom of the pedal ,mech says may have to make a spacer for the release bearing to engage it earlier . This car is a 96 328 Is sport , second 1 ive had but its different , has a spoiler at top of rear wnidow & a wing , dual airbags & heated seats . different climate controls . . Although NZ new i wonder if its a Sth africa assembled ? Ill put the 325 kit inc new plate on Tm & the dual mass plate for the 328 , hope to off set the costs Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted May 18, 2017 Not to be disrespectful or anything, but your lack of formatting makes it very hard to follow. Also Brent @ BM World knows his stuff. I recommend either giving him a call and/or writing a clear list of what you actually have and a separate list of what you want. Lots of e36s have been manual converted, so you can't rely on everything you find being factory (unless of course you have proof). Parts are also plentiful, so you shouldn't have to make a spacer or use any custom parts. 2 Quote Share this post Link to post Share on other sites
mal6 0 Report post Posted May 22, 2017 Tried him didnt reply . Its an after market liteweight steel motor sport flywheel ex USA , bought new clutch cover & plate from Auto Brake & Clutch . they identified the flywheel & now have fitted a new slave cylinder but . still has fairly long pedal travel . Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted May 22, 2017 On 5/22/2017 at 2:55 AM, mal6 said: Tried him didnt reply . Its an after market liteweight steel motor sport flywheel ex USA , bought new clutch cover & plate from Auto Brake & Clutch . they identified the flywheel & now have fitted a new slave cylinder but . still has fairly long pedal travel . I missed your call , tried to call back a few times , no anaswer 1 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 22, 2017 I would say the release bearing carrier is the wrong one. There are 2 types, one is 10mm longer than the other 1 Quote Share this post Link to post Share on other sites
