nick496 271 Report post Posted May 30, 2017 (edited) After E30 Headlight washer kit to add back onto my E30. If it helps, I believe I only need the wipers + motors, the squirting rings, and the fluid container. The wiring seems to still all be there... Photo from back in 2011 or so (prior to my ownership) Edited May 30, 2017 by nick496 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3027 Report post Posted May 30, 2017 I've got a set of motors and wipers I can let go, not sure about "squirter rings" I've got the jets that push through the plastic grilles and a few other bits and pieces. Quote Share this post Link to post Share on other sites
nick496 271 Report post Posted May 30, 2017 PM'd. Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted May 31, 2017 There are specific headlight rings which have allowance for mounting the stoppers. I think each ring for each light is unique so you will need a full set. Only important if you actually want to run the wipers. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted May 31, 2017 Check if your current grills don't already have the squirters, they're actually pretty nondescript and I believe they're the same as an e28 (if you can separate the squirter from the grill). Do you want upload a picture of your current grills? Quote Share this post Link to post Share on other sites
nick496 271 Report post Posted June 20, 2017 Yep, pretty sure the grills don't have squirters :/ I'd like them to work, but it's not critical. Quote Share this post Link to post Share on other sites
