nick496
WTB E30 Headlight Washers
After E30 Headlight washer kit to add back onto my E30.
If it helps, I believe I only need the wipers + motors, the squirting rings, and the fluid container.
The wiring seems to still all be there...
Photo from back in 2011 or so (prior to my ownership)
Edited by nick496
I've got a set of motors and wipers I can let go, not sure about "squirter rings" I've got the jets that push through the plastic grilles and a few other bits and pieces.
There are specific headlight rings which have allowance for mounting the stoppers. I think each ring for each light is unique so you will need a full set. Only important if you actually want to run the wipers.
Check if your current grills don't already have the squirters, they're actually pretty nondescript and I believe they're the same as an e28  (if you can separate the squirter from the grill). Do you want upload a picture of your current grills?
Yep, pretty sure the grills don't have squirters :/
I'd like them to work, but it's not critical.
