Benji335i 21 Report post Posted June 25, 2017 Just wondering if oil leaks are a common problem with this engine? can anyone recommend anywhere to fix the issue asap!! Quote Share this post Link to post Share on other sites
Gaz 1067 Report post Posted June 25, 2017 Turbo oil feeds and rocker cover probably the most common ones Quote Share this post Link to post Share on other sites
Stevie S 49 Report post Posted June 26, 2017 Oil filter housing gaskets are a common area that leak. BM workshop in Grey Lynn are good cats. I have a spare replacement set of new oem Rubbers for that leak if thats your issue. Quote Share this post Link to post Share on other sites
Benji335i 21 Report post Posted June 26, 2017 Thanks guys for the help. the car is booked in with BM workshop to see what the leak is and fix it!! Quote Share this post Link to post Share on other sites
Herbmiester 946 Report post Posted June 26, 2017 My 335i had a rocker cover leak at 75,000kms. Quote Share this post Link to post Share on other sites
Benji335i 21 Report post Posted June 26, 2017 Does this help you guys help me diagnose the problem? Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted June 26, 2017 Could be from a few different places, mine was also dripping from the same sort of location when the oil filter housing gasket failed. I think you also have a n55 not n54 Quote Share this post Link to post Share on other sites
Benji335i 21 Report post Posted June 26, 2017 I have an N54 for sure I have two downpipes I know it looks like one from one of the angles of the picture. If it's leaking from a few places what would they be. I just wanna go prepared when I go sort my car out! Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted June 26, 2017 Oh woops the angle of the photo got me. But it's just hard to guess without having a good look, that area seems to be where the oil runs and collects so it'll be a guessing game without having a proper look Quote Share this post Link to post Share on other sites
Olaf 3394 Report post Posted June 26, 2017 That's not an oil leak! You should try living with a turbocharged Volvo, that's more like an oil leak! ? Quote Share this post Link to post Share on other sites
Benji335i 21 Report post Posted June 27, 2017 Lol from that reply I feel its an easy fix like gaskets or o rings or something it's booked in at bm workshop so hopefully it's a quick turn around Quote Share this post Link to post Share on other sites
jin108 25 Report post Posted June 27, 2017 On 6/25/2017 at 11:10 PM, Benji335i said: Just wondering if oil leaks are a common problem with this engine? can anyone recommend anywhere to fix the issue asap!! Do you have an N54 aka the oil fountain? On those yes oil leaks are common. 1 Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted June 27, 2017 Haha once you get the common areas sorted I believe they're pretty reliable. You guys making me feel better about choosing the N55 ? Quote Share this post Link to post Share on other sites
Benji335i 21 Report post Posted June 27, 2017 Haha that's what I'll do!! Remember the N54 can give a lot more power plus its forged, well crank and rods are!! Quote Share this post Link to post Share on other sites
Nasian101 4 Report post Posted July 14, 2017 On 6/26/2017 at 8:09 AM, Herbmiester said: My 335i had a rocker cover leak at 75,000kms. How much was this to fix if you don't mind me asking? Quote Share this post Link to post Share on other sites
Herbmiester 946 Report post Posted July 14, 2017 It to was around $500, mostly labour. Quote Share this post Link to post Share on other sites
