exextatic 156 Report post Posted July 13, 2017 In the middle of re-powering my 523i touring with an M54B30 and need to sort out the fuel system. As the M54 is returnless (as opposed to the M52), and the fuel pressure regulator is integrated into the fuel pressure regulator, the fuel lines are different. I'm looking for the highlighted parts in the following diagram, which are found in any later-model E39s with an M54 or M62 engine: Quote Share this post Link to post Share on other sites
HardBall66 135 Report post Posted July 14, 2017 Schmiedmann should have all those parts - just plug the part numbers into their search box. Shipping from Europe is not too bad on small/light parts, and no VAT or GST if the order is under ~ $400 IIRC 1 Quote Share this post Link to post Share on other sites
exextatic 156 Report post Posted July 14, 2017 1 hour ago, HardBall66 said: Schmiedmann should have all those parts - just plug the part numbers into their search box. Shipping from Europe is not too bad on small/light parts, and no VAT or GST if the order is under ~ $400 IIRC Thanks Matt, but was hoping to source them locally if possible. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 14, 2017 You will be able to get them locally, but maybe they will need to order them in from overseas. They will be much more expensive locally too. Quote Share this post Link to post Share on other sites
hqstu 780 Report post Posted July 14, 2017 Schmiedmann - quick, easy, cheapest. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted July 14, 2017 Aren't they on their summer holiday at the mo? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 14, 2017 Yep. Quote Share this post Link to post Share on other sites
exextatic 156 Report post Posted July 15, 2017 Hi all; Ray @ HellBM has ended up sorting me out. Quote Share this post Link to post Share on other sites
