drtimwright 104 Report post Posted October 26, 2017 Hey everyone, My car (1998, E36, 328i) just started hissing from the front and a bit of steam coming out. The steam didn't last long. The hissing lasted 5 or 10 minutes (so far...) The sound comes most strongly from the front left grill (as you face the same way as the car - so passenger side). So I suspect a cooling system issue. There is no coolant leak on the ground and a visual inspection (at night with phone torch) didn't see anything obvious. The radiator was replaced about 6 months ago. The reservoir tank is on the same side as the hissing. Anyone have any ideas - and do you think I can drive it to get it to the mechanic? (it's a 10-15 min drive to the guy I see). I'll check the level tomorrow once the engine cools down. Thanks! Tim Quote Share this post Link to post Share on other sites
gjm 3276 Report post Posted October 26, 2017 Almost definitely cooling system. Was the replacement rad a new one? Any hoses on that side of the rad? Quote Share this post Link to post Share on other sites
drtimwright 104 Report post Posted October 26, 2017 3 minutes ago, gjm said: Almost definitely cooling system. Was the replacement rad a new one? Any hoses on that side of the rad? Replacement was new. I think there is a hose on that side - might check if it's attached properly in the sunlight. Quote Share this post Link to post Share on other sites
TermiPeteNZ 1325 Report post Posted October 26, 2017 Crap - sorry you're having a bad run Tim :| Quote Share this post Link to post Share on other sites
drtimwright 104 Report post Posted October 26, 2017 Looks like one of the hoses connecting to the radiator is bulging. And there is an oil leak coming from the engine - the oil pump perhaps? Quote Share this post Link to post Share on other sites
gjm 3276 Report post Posted October 26, 2017 I regard hoses as a regular service item, especially on BMWs. It's not much to change, but worth checking the hose condition. It could be bulging because of age, or it may be a symptom of something else. The oil leak - does it look like a mist which has applied itself to anything it touches? What's the yellow in the pic? Quote Share this post Link to post Share on other sites
drtimwright 104 Report post Posted October 26, 2017 1 minute ago, gjm said: I regard hoses as a regular service item, especially on BMWs. It's not much to change, but worth checking the hose condition. It could be bulging because of age, or it may be a symptom of something else. The oil leak - does it look like a mist which has applied itself to anything it touches? What's the yellow in the pic? The yellow is pine pollen on my driveway The oil is only on that thing and the pipe that comes out the bottom of it - until the pipe goes horizontal then the oil goes away. The oil looks kinda misty but it's only on that one thing - whatever it is! Tim Quote Share this post Link to post Share on other sites
gjm 3276 Report post Posted October 27, 2017 1 hour ago, drtimwright said: The yellow is pine pollen on my driveway That's one thing less to worry about! 1 hour ago, drtimwright said: The oil is only on that thing and the pipe that comes out the bottom of it - until the pipe goes horizontal then the oil goes away. The oil looks kinda misty but it's only on that one thing - whatever it is! I think that's the power steering fluid reservoir. We need to try to diagnose what sort of oil you have misting on the surface. Always fun - all oil turns black when it's where it shouldn't be! Try wiping it with a clean white cloth (just kitchen paper towel will do) - if there's any red in it, it's probably PS fluid. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted October 27, 2017 The PS reservoir can leak when full/overfull under hard cornering (comes out the bleed holes in the cap) 1 Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted October 27, 2017 11 minutes ago, eliongater said: The PS reservoir can leak when full/overfull under hard cornering (comes out the bleed holes in the cap) His does look grimy in the picture too. This is really obvious on a close inspection. Mine had goo all over it before being replaced. Quote Share this post Link to post Share on other sites
gjm 3276 Report post Posted October 27, 2017 23 minutes ago, eliongater said: The PS reservoir can leak when full/overfull under hard cornering (comes out the bleed holes in the cap) I'd forgotten about that. (No PS on the E30... ) Quote Share this post Link to post Share on other sites
drtimwright 104 Report post Posted October 27, 2017 2 hours ago, eliongater said: The PS reservoir can leak when full/overfull under hard cornering (comes out the bleed holes in the cap) Well, it's not like I drive over the Remutaka pass every day in an overpowered old car...no wait...that might be me... I wiped the thing off the 'oil' was mostly oily black soot (see attached photo). Which means it might be an old PS leak that's since carbonized and I should drive more moderately. Tim 2 Quote Share this post Link to post Share on other sites
Neal 553 Report post Posted October 27, 2017 On the radiator front the wifes e36 328i did a similar thing last weekend. Noticed the coolant coming out from somewhere near the top of the overflow tank. The tank was replaced last year. I bought a new radiator cap and took off and put on and re-tighten the top hose into it and did a basic top up with water. Cooling system was now holding pressure. Went or a drive and found it needed further coolant. Put car on step part of driveway nose up. Turned on heater and bleed system. Got wife to do a couple of short drives and rechecked ... all good. Will replace the water with anti-freeze this weekend. 1 Quote Share this post Link to post Share on other sites
