M M 250 Report post Posted November 9, 2017 (edited) Before I pull my LSD diff apart to change the ring gear, does anyone have an E28/E24/E23 large case LSD diff with a ratio of 3.46 or higher that they would either sell or trade for my 3.07? May consider medium case E30 diffs depending on price. Can do cash your way, again depending on the diff. Not interested in non LSD or anything not bolt in, because I have a non bolt in solution already. Looking for an easy option. I'm in Auckland but don't mind dealing with shipping. Edited November 9, 2017 by M M Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted November 9, 2017 go to med case if you can free up some rear wheel HP , (i gained about 10hp on my old e28 ) I have a medium 3.91 e34 lsd , but you will need to find a MED E28 diff case to swap the guts into Quote Share this post Link to post Share on other sites
M M 250 Report post Posted November 9, 2017 7 minutes ago, BM WORLD said: go to med case if you can free up some rear wheel HP , (i gained about 10hp on my old e28 ) I have a medium 3.91 e34 lsd , but you will need to find a MED E28 diff case to swap the guts into I actually do have a medium case open diff which I could use. If nothing else comes up I may take you up on this. How much do you want for it? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 9, 2017 Try Kayne Barrie Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted November 9, 2017 54 minutes ago, M M said: I actually do have a medium case open diff which I could use. If nothing else comes up I may take you up on this. How much do you want for it? $875 for this one thanks Quote Share this post Link to post Share on other sites
