Michael. 2313 Report post Posted March 25, 2018 Curious to know some specs on the M54B30 and S54B32 Particularly length from the back of the engine to the front of the accessories, height from bottom of sump and width cylinder head to intake manifold side (basically major extremities) Also like to know the dressed weights, preferably with all accessories and fluids of the engines less trans, any figures would be useful though. Seen a lot of figures of the block weights, short or long - but rather know actual weights with everything. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted March 25, 2018 These have some info not sure it's what you are after http://www.dukeengines.com/advantages/weight-size-shape/ http://forum.e46fanatics.com/showthread.php?t=730757 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted March 25, 2018 Weights here; http://mywikimotors.com/m54b30/ 130kg http://mywikimotors.com/bmw-s54/ 149kg The s54 lost a little weight on the head, but gained alot on the block as it was iron. 1 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted March 25, 2018 3 hours ago, Michael. said: Curious to know some specs on the M54B30 and S54B32 Particularly length from the back of the engine to the front of the accessories, height from bottom of sump and width cylinder head to intake manifold side (basically major extremities) Also like to know the dressed weights, preferably with all accessories and fluids of the engines less trans, any figures would be useful though. Seen a lot of figures of the block weights, short or long - but rather know actual weights with everything. have engines in stock if you want to come measure 4 Quote Share this post Link to post Share on other sites
